Question about Sony VAIO VGN-SZ460N/C Notebook
My sony vaio does not start up, when I connect the AC adapter, green light on adapter blinks. Any help?
  • nitish goel May 07, 2013
    I am experiencing the same problem. If you got the problem fixed, can you please let me know the solution as well? thanks a lot. you can inbox me on [email protected] as well. thanks a ton.
SOURCE:
Tech 75
  • 85 Answers
SOURCE: Sony Vaio PCG 7v2l won't turn on
this may or may not be the solution but its some sort of indication of what is going on. Ok when you plug the ac adapter do u get a flashing light to indicate your batter is being charged? If you do then there is power going through the laptop to the battery, which is great. Now if you don't have the indicator flashing then it could be that the where the AC adapter plugs to the laptop could be now faulty. The other one could be that the AC adapter plug i.e. head that goes into the laptop some how internally has a severed connection.
comment on what you find and ill see what else i can advice :)
Plz rate me
Posted on Jun 02, 2009
  • 14 Answers
SOURCE: My sony vaio vgn-fs285e will not switch on.
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Posted on Oct 20, 2009
rulds2008
  • 3866 Answers
SOURCE: sony vaio cr35 power problem
You might have a hardware failure here. Specially the part when you said you had the same result when removing the battery and just had the AC in. This machine has NO POST this mean Hardware failure specially the blinking light concerns me on the machine health as far as a tech. I would say bring it into the geek squad to confirm my theory it will not hurt for them to take a few secounds to confirm this if there is any warranties I cannot stress this enought use the warranty this is your secure ticket to a fix if its not warrantied I would seriously recommend having the motherboard evaluated it should at least beep but if you do not get a beep this is NO POST hard ware failure. Thanks and please rate you experience with me postivly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 17, 2009
Testimonial: "thanks for the advise. I will send it to the service center for evaluation. Thanks very much"
  • 6 Answers
SOURCE: sony vaio pcg-r505el won't turn on
These are know to have issues with the cpacitors on the mother board, you can try to replace the caps or just buy a new motherboard. I'm fixing one right now as I type...
Posted on Jan 15, 2010
  • 6 Answers
SOURCE: my sony vaio vgn-cr220e/r battery will not charge
I suggest you buy a new sony vgp-bps9 battery at battery center
Posted on Jun 28, 2010
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
How do I know if my sony vaio laptop is charging
theres always a light blinking orange to green if im correct.
good luck.
Jun 25, 2013 | Sony Stick AC Adapter with USB Charging...
Recently, the battery of my vaio died, but I could still manage by getting the power from outside sourse. However, I couldn't even turn it on last night, even though the vaio was still getting the power...
eventhough the light indicator on the ac adapter is still working, it doesnt mean that the ac adapter is still working fine..
  • the problem could be the ac adaptor itself, the dc in port of the computer or maybe the motherboard.
if the computer is still in the warranty, sony will cover the battery, ac adapter replacement, or process repair if needed. you can call them at 888 476 6972 or 239 768 7669
Mar 15, 2010 | Sony Computers & Internet
Firstly the ac adapater went donw than a bought a new one and now my Sony vaio is Bllinking the red light what can be?
maybe the battery is very low, that's why its blinking or the new ac adapter you bought is not compatible with the computer.
That's why its blinking the red light.
Take care.
Mar 05, 2010 | Sony VAIO PCG-K35 Notebook
My vaio will not turn on. The green light and
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM or memory
  4. press and hold down the power button for 7-10secs to release static electricity
  5. reconnect the battery and ac adapter
  6. try turning it on
if still no go, unit needs service
Feb 08, 2010 | Sony VAIO Notebook
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Feb 18, 2009 | Sony VAIO GRT170 Notebook
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony VAIO VGN-SZ460N/C Notebook Logo
111 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
