Question about Horizon Exercise & Fitness
Fix magnets on Johnson integrated drivers JM05-015
    Top Expert:
  • Horizon Master
  • 12,223 Answers
fix magnets on Johnson integrated  drivers JM05-01 - 1_21_2013_5_49_11_pm.gifTest for open or faulty,clean it, and tight the connector very well. God bless you
Posted on Jan 21, 2013
I have a 1974 50 hrs johnson it turns over but not getting no spark put new cdi box two new coils new primar bubble new gas lines checked all conections need help
IF this is a 50 Hp Johnson marine motor, you may have a problem with the flywheel magnet or the stator coil that is under it.
Feb 14, 2018 | GAS Motorcycles
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
Instructions to fit fixing kit to a hul161i integral fridge door
Why not using doubleside type to put the magnet on , start atleast by turning of the unit for three days so everything can be made clean and dry
Feb 15, 2014 | 760Li Brief instructions f01, f02, f03....
Error 3 (E3) on Schwinn 240 recumbent bike. How can I fix it?
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
May 23, 2010 | Schwinn Exercise & Fitness
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Changing door hinge position
you could try and pop off the door seal from the w/m front and reach down to see if retrieval is possible.
Jan 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Exercise & Fitness Logo
300 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
