Question about U-Line Icemaker
The problem; water drips from beneath the ice maker inside the cooling area. This water eventually freezes and turns the whole ice maker compartment into a block of ice.
  • hgm54 Apr 20, 2009
    I have the same problem in my U-line .BI 98 ice maker. Very annoying. Plumber came to stop the leaking water and since he did not "repair appliances" he thought it was calcium build up,, but was unsure how to fix. The solenoid controls water to the tray and has to be level to work right. Lines are suppose to be self cleaning, but if turned off/on calcium builds up and causes this problem. Will advise after "repair guy" arrives
    Problem Solver:
  • 4 Answers
YOUR ICE MAKER IS OVER FLOWING, MAY HAVE DEBRI IN THE WATER VAULVE BEHIND YOUR FRIDGE, I HAD THIS PROBLEM 2 YRS AGO AND REPLACED ALL KINDS OF GADGETS IN THE FREEZER, AND FOR ME IT WAS CALCIM DEPOSIT IN THE VALVE , NEVER WOULD HAVE THOUGHT. I HOPE THIS HELPS, AND I HOPE YOUR PROBLEM IS MINOR. YOU HAVE A GOOD DAY. LYNDA
Posted on Jan 26, 2009
Technician diagnosed it as a bad water inlet valve aka solenoid. Replace it and problem solved.
Posted on Apr 20, 2009
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
Mar 20, 2015 | Kitchen Appliances - Others
CLR2060 Clear Ice Maker Won't Freeze
might be low on freon check it
Aug 08, 2008 | U-Line Icemaker
My NewAir Portable Ice Maker no longer makes ice. It pumps water up into the resvior but the fan motor never turns on and it does not freeze the water. Why is it acting this way?
is the compressor hot? if so, the fan might be dead. the condenser needs air flow to cool down. if the compressor doesn't even turn on, the starter coil (inside the box on the front of the compressor) may be shot.
Feb 20, 2014 | New Air NewAir AI-100S Portable Ice Maker
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
Melting ice
The bin has most likely failed. Apparently the bin insulation on the DCE33 eventually gets saturated with water and loses it's insulation ability. Consequently the ice melts prematurely. Condensation starts to build up inside the bin because it's not cold enough adding to the problem as the water drips on the new ice inside the bin.
Mine is 5-yrs old and I was told that it's all the life I'll get out of it.
If everything else is workng properly, harvest time, cube size, cold water spray, then a new bin is the unfortunate solution.
Apr 02, 2012 | Scotsman DCE33PA1BC 15in Built-in...
Does not make ice power supply is good refrigeration light is blinking
Shawn,
Check you drain system, does the unit retain water inside the unit at the storage compartment? Normally the cooling system will not function if the unit can't empty all the water using and external drain system. Good Luck...
Jul 12, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
Not making Ice
Is the freezer at least 10 degrees? Is there water in the ice mold? If not put some to see if it will harvest after it freezes. If no water getting to ice mold Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | Marvel Appliance Ice Maker
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
U-Line Icemaker Logo
164 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Iron
Iron
Gil Shultz
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
