Question about Maytag Neptune MAH5500B Front Load Washer
DOOR LOCK DOES NOT ENGAGE - Maytag Neptune MAH5500B Front Load Washer
  • Maytag Master
  • 17,129 Answers
Please check this link; Door lock
Posted on Jan 21, 2013
Door locks keep engaging while I drive.2001 Montana extended van.I leave it in the garage unlocked and come back later to find it locked.What is the problem?
most gm cars engage the door locks when the vehicle is in gear and is up to 12 miles per hour. Not aware of an ease way to prevent the locks from engaging when moving. Really can be annoying but not such a bad thing these days with car jacking and other crimes to have the doors lock.
Mar 21, 2017 | 2001 Pontiac Montana
When i closed door it does not auto lock by itself
vehicle doors dont auto lock unless either you start vehicle and put in gear and than lock will engage or with key fob when you leave vehicle and engage lock on fob ---but for saftey and for unnecessary lockout calls vehicle doesnt auto lock when door is closed
May 22, 2016 | 2008 Volvo XC90
Door lock is engaged but door is open. panel says door locked. how do I release lock so door will close?
Hello Maureen, thank you for your post!
I see that your Frigidaire range is currently displaying door lock engaged except the door is open. The best way to release the door lock is to hold down the cancel button for at least ten seconds. If that does not help release the door lock I would suggest disconnecting power from your range for at least ten minutes. We hope that this information is helpful towards the repair of your range. -Matt
Feb 01, 2016 | Frigidaire Kitchen Ranges
Power door lock does not engage lock works manually
Try wiggling the electrical harness between the door and body of the truck with the door open and switch engaged.
Aug 07, 2012 | 1995 Chevrolet Tahoe
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
2007 Chevy equinox door lock latches engaged
Did you unlock doors and pull handles like to open, then try?
Mar 13, 2009 | 2006 Chevrolet Equinox
Maytag Neptune MAH5500B Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
