Question about GE Spacemaker JVM1640SJ Microwave Oven
Blown microwave oven lamp
We have a Panasonic NN-K655 microwave oven but have no idea how to replace the lampwithout taking the oven apart! Am I missing something?
Many thanks
  • GE Master
  • 5,568 Answers
If you don't see a removable panel inside the cavity, yes, it will have to get nekkid. Obviously, pull the AC plug first; there are potential very dangerous uninsulated points inside.
It shouldn't be too tough, there are normally only 5-8 screws along the edge of the back panel to be removed, then lifting the back edge of the housing should free it from the front lip and it should slide off. Sometimes, finding one of the compact bulbs is more work than the replacement of it.
Posted on Jan 26, 2009
Change the bulb
Remove the top cover by removing the side screws of the top cover. The chamber lamp is mounted within the slit of the top and will be visible. You can remove the covers to get to the lamp. replace with the same type and thread. if the lamp has not blown it can be due to faulty switch or relay.Trace the lamp circuit to confirm the fault
Jan 10, 2013 | Panasonic NN-S769 Microwave Oven
Can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
The lamp replacement requires complete removal of the oven external casing. The oven must be tested for radiation leakage after the repair. The replacement must be done by a trained technician. Disassembling procedure is illustrated on the service manual available here: Panasonic Service/repair manuals,schematics.
Regards.
Ginko
Dec 15, 2011 | Panasonic Microwave Ovens
How do yo change a blown light on a NN-T774SF micro wave
just disconnect from the power and take out the screws from the cover around and you will see a plastic color white then remove a screw from them and you find the bulb replace and return all parts back
Apr 01, 2011 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic NN S254BF
It sounds like one of the wires or serkits are loos so the electrisity is not getting to it all the way I would return it or take it apart and try to fix it your self.
Dec 29, 2007 | Panasonic NN-S254BF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
130 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
