Question about New Home HF-2022
How to thread a New Home hf2022 sewing machine
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
JeremySew
  • 65 Answers
SOURCE: Manual
I found the manual you are looking for here:
Newhome Instruction / Owners Manuals
Posted on Dec 16, 2008
SOURCE: bobbin threading
I need to find a needle threader for a sx 2122. I am find it impossible to find one. I lost the little spring that goes in it. Please help
Posted on Jan 26, 2009
  • 240 Answers
SOURCE: The needle doesn't catch the thread in the bobbin
Are you certain the needle is not bent and that it is in the right way around? Which model is it?(I used to sell them)
Posted on Jun 21, 2009
  • 980 Answers
SOURCE: machine won't sew. tensions been checked, above
make sure the needle is in the correct way round that is the most common cause
Posted on Jun 19, 2010
Need to know how to thread the new home model 654 sewing machine
You can get a manual for your machine here:
Janome New Home sewing machine instruction manuals
This video may be helpful. Machines usually thread similarly.
Janome New Home Special Edition
Dec 21, 2017 | New Home Sewing Machines
How to thread 960 new home sewing machine
Perhaps this will help. Machines tend to thread similarly unless there was a big change between models.
New Home Model 532 Sewing Machine Threading Diagram
Feb 27, 2017 | New Home Sewing Machines
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Make It Handmade Threading Your Serger or Overlocker
Nov 25, 2016 | New Home Sewing Machines
Where is the button to raise and lower feed dogs on the Janome/New Home HF2022
Set the length to zero and the feed dogs will go under the plate.
Oct 23, 2014 | Sewing Machines
Janome model us 2022
here are 3 links for a janome 2022 for any other part you'll have to contact a janome dealer or check ebay
Janome 2022 Parts Janome DX2022 Parts Janome HF2022 Parts
May 01, 2014 | New Home Sewing Machines
Manual
Dec 16, 2008 | New Home HF-2022
Bobbing Winding
i have and love this machine...pull out the large side knob on the right side of machine and switch the bobbin to the right side on the metal winder at the top.you will hear a little pop on those 2 steps...put a thread thru the hole in your bobbin and give your foot pedal some pressure....really easy
sonyainkaty@sbcglobal.net
Jun 02, 2007 | New Home HF-2022
New Home HF-2022 Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
