Question about Husqvarna Sewing Machines
I am looking for the instruction manual for the Husqvarna Viking "Quilt so Clever" used with the 18 x 8 quilter
    Scholar:
  • Husqvarna Expert
  • 104 Answers
I d don't know anything about this software but here's a website that may be helpful: http://usaapp.husqvarnaviking.com/canada/dealers/dealer_club/notions_QuiltSewClever.html
Posted on Jan 31, 2013
  • 152 Answers
SOURCE: I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Posted on Oct 06, 2009
  • 152 Answers
SOURCE: I am looking for a manual for a viking husqvarna
Call Husqvarna at: 1-800-474-6437. They may be able to get you a photo copy of the original owners manual.
Posted on Oct 15, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
Posted on Nov 02, 2009
  • 201 Answers
SOURCE: I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Posted on Jul 17, 2010
Testimonial: "Thanks so much for your feedback on the Quilter's Hoop problem. I did as you suggested putting the Large Hoop 240x150 in the preferences and darn if it didn't work. I have since learned that my technician wants $50.00 for a part he says Husqvarna says my machine needs because it was built before the Quilter's Hoop came on the market. What do you think of that? Thanks again for the solution."
SOURCE: Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
Posted on Feb 18, 2011
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Quilt Sew Clever
If you need a different brand try brother sewing machines .Maybe your machine is not compatible with the capacity of your electricity.
Sep 17, 2012 | Sewing Machines
My Husqvarna viking 18x8 quilter will not quilt side to side only up & down.
You might check your rear encoder - this is the one mounted to the bottom of the roller base. If it is not making contact or is not plugged in correctly on both ends your machine will have this issue. This encoder could need to be replaced. This mostly affects the regulated stitch mode, but can also affect constant stitiching as well.
May 28, 2011 | Husqvarna Sewing Machines
Raise feed dog
May 19, 2010 | Husqvarna Viking 1
I have a Quilt Designer II that is not sewing properly. I am told that the "timing" is off but cannot find out how to fix it. I do not want to send it away. I have looked for a manual to get instructions...
Setting the "timing" is something that should be done only by an authorized husqvarna viking dealer. Many dealers have inhouse service technicians certified by HV. I would look for such a store in your area. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 07, 2010 | Husqvarna Viking 1
Bobin thread wads up. I have a viking mega quilter and frame. I have removed all the threads several times, but each time I try to quilt, the cruise control can only move about an inch, and the bobbin has...
just a thought but maybe your bobbin thread is wound on to loose,try to rewind it holding onto the thread to give a tigher tension while going onto the bobbin
Dec 20, 2009 | Husqvarna Viking 1
Nov 01, 2009 | Husqvarna Viking 1
Sewing Machines Logo
111 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
