Question about Whirlpool Washing Machines
Cutting tap off after each cycle
Do I have to turn tap off after every wash?
    Sergeant:
  • 291 Answers
You shouldn't have to, but some machine manufacturers suggest it. Refer to the owner's manual. If you don't have one give me your model number and i will try to find one for you. Model number is usually on inside of loading door. Are you finding water in the tub after machine has been idle?
Posted on Jan 20, 2013
2 Suggested Answers
  • 1028 Answers
SOURCE: Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Posted on Sep 01, 2008
Washing machine takes about 1 hour between prewash and spin dry cycle. Water just dribbles in.
check the operation of the solenoid valve
check that the tap washer is opening with the turning of the tap as they can become enlarged and jam in the hole in the tap
Sep 06, 2015 | Washing Machines
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
Water underneath unit
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water underneath unit?
I have a wtw5800swo washer. The washer will complete the wash cycle, but then shuts off and will not enter the rinse cycle.
Be sure to guarantee that BOTH hot and cold taps are turned on. Commonly, the hoses get reversed, and dad turns off the hot water (due to high bills) and the hot is connected to the cold tap, which is used for rinse, so the machine will wait forever for the water...
Apr 07, 2011 | Whirlpool WTW5850S Top Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Sep 01, 2008 | Washing Machines
Westinghouse washer lT609s - tap problem
if I understand you correctly ... your washer keeps filling with water and you must shut them off at the wall to stop the water from coming into it?
this is a stuck water valve .. there may be something in your water valve keeping it open...
unhook your hoses and check them..
hope this helps
Apr 05, 2008 | Washing Machines
Whirlpool AWM6100 - Will starrt but then just stops part way through the cycle
it may be the door switch cutting out if you push on the door does it start.does the water come in before it cuts out.will it work on spin or does it cut out as well.if its only on wash it may be a valve problem.are both the taps turned on.its hard to know without being there.hope this is helpfull.Ian.ps you may have a board fault.
Mar 08, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
