Question about Planet Audio GPS
Need a manual for a planet audio tt2150 amplifier
Tt2150 manual
5 Suggested Answers
  • 631 Answers
SOURCE: planet audio amplifier
There are several options.
Take the jack out of the board, disassemble it and remove the tip of the plug.
If the tip of the plug is in the top slot, pull the sleeve off of the jack and remove the tip of the plug. When you press the sleeve back into the jack, bend the tab inside the jack up so it will remain firmly in place.
Use the output jacks as the inputs. It's very likely that they're in parallel. The only difference being a low value resistor (will have no effect on the signal) in series with the output jack.
Posted on Mar 29, 2008
catally733
  • 117 Answers
SOURCE: i'm fixing a vx2200d planet audio amplifier but it
under the resistor ,there should be a value ,it may be silkscreened on the board . neighboring ones if the same size or opposite the burned one may have the value in stripes u can see , try ohm meter and check the burned one , it may not be "open" u can read it that way
Posted on Jan 16, 2010
SOURCE: How do I put the fuses in a 3000 watt planet audio
Do you know where the fuse is?
If you do you just take the old fuse out and put the new one in.
If you do not know where the fuse is, just look for it, thereare not so many place to look.
Good luck
kolbrun
Posted on Apr 10, 2012
I need a manual for my planet audio p9720
I would recommend contacting Planet Audio Directly: 1-888-990-1236
Oct 19, 2015 | Planet Audio Car Audio & Video
Planet audio px1500m
To many toys not enough power ...... Extra battery or bigger alternator
Nov 07, 2013 | Planet Audio PX1500M Mosfet Monoblock...
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
How many planet?
only 9 planet in this universe bobo
Apr 02, 2011 | Planet Audio VX4002 Car Audio Amplifier
I Need VX2200D Diagram by Planet Audio
You can find a user manual with the wiring diagram at planet audio's website. Here is a link to a pdf of the manual: http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg">http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg
Mar 04, 2011 | Car Audio & Video
Cuando lo conecto SE VA A corto
el mio tambien es un planet audio rxd2400 monoblock y me dicen que se proteje de echo donde lo lleve tenian otros dos iguales descompuestos de lo mismo osea ya son 3 no se si alguien sabe decifrar como reparar estos amplis mi correo para algun dato que sirva mmgl_angg@hotmail.com
Nov 22, 2009 | Planet Audio VX3002 Car Audio Amplifier
Straping planet audio vx900d's
Specs
  • VX900D
  • 1 X 375 RMS @ 4 Ohms
  • 1 X 650 RMS @ 2 Ohms
  • 1 X 900 W RMS @ 1Ohms
  • Dimensions 10-1/4" (L) x 2-7/16" (H) x
    Click on the link below. It will take you to the official Planet Audio website. In the search box on the right hand side, type VX900D and it will bring it up. Click on Download and it will download the installation manual for VX900D including a diagram on how to strap (on Page 9).
    Remember that you must only run on a min load of 2 ohm when strapping or you may damage the amplifiers and void you warranty.
    http://www.planetaudiousa.com/support/index.php
  • Nov 04, 2009 | Car Audio & Video
    I have a Planet Audio VX900
    why do you need a car with an eeprom to operate your amplifier?
    May 09, 2008 | Planet Audio VX900 Car Audio Amplifier
    Planet audio vx3002
    Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
    Features of Planet Audio VX3002:
    • Max Power (2 Ohms) : 300W x 2
    • RMS Power (4 Ohms) : 150W x 2
    • Bridged Power (4 Ohms) : 600W x 1
    • Signal-to-Noise Ratio : 102dB
    • Frequency Response : 20Hz-20kHz
    • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
    Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
    GPS Logo
    26 people viewed this question
    Top Planet Audio GPS Experts
    Are you a Planet Audio GPS Expert? Answer questions, earn points and help others
