Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
How do you loosen stubborn set screw on #7437 moen kit faucet
Thank 0
  • skinmon1953 Jan 27, 2009
    already tried the wd40
  • 10,865 Answers
Squirt a little wd40 on it and wait ten minutes. good luck
Posted on Jan 26, 2009
How do remove the handle of my faucet that does not have a cap cover or a screw
Hello, You will need an allen key to remove the handle. it is in front of the handle, I beleave it is a 7/32 size key. un- screw and lift off, this should help.
Mar 04, 2015 | Moen 7437 Chateau Single Hole Kitchen...
I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
How do i replace gasket on moen facuet in bathroom sink
On a Moen Faucet the set screw is behind the little "blue and red plastic tab", remove this tab very carefully with a small flat screwdriver. Then you should be able to see the set screw. make sure to turn of the water supply under the sink first. The set screw will probably be an "allen head" type and you will need an allen head wrench. This is a hex shaped 6-sided tool in a rod shape and is available at your local hardware in a set. Next you will need the model # of your faucet and take this to your local hardware to match with a repare kit. Moen usually has a lifetime warranty and if you have your paperwork just call Moen directly and they will send you a free replacement kit, free shipping too. The kit has installation instructions with it.
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
How do you remove the handle on the 7437 chateau single hande
Did you try popping out the little red and blue button at base of handle, there should be an Allen screw in behind that, to loosen and remove.
Jan 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Please recommend a sink to use with moen 7437 I need to use double sink
Hi, W/D here.
Whether it is surface or undermounted, My recommendation is to purchase the heaviest grade (gauge) of metal if installing stainless steel. If you are putting in an enameled sink, Kohler makes some very good ones.
Best regards, --W/D--
Aug 12, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Trying to get the handle off a single handle moen kitchen faucet
Hi adelinette,
Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
Good Luck and please rate this response, Phil
Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Lever will not stay in position
There is a nut in the handle mechanism that needs to be snugged up (adjusted). There is an exploded view of this faucet at http://www.moen.com/shared/pdf/7430pt.pdf
Let me know if I can help you further, -CompuWayne
Dec 31, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
277 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
