Question about AEG Washing Machines
Anti flooding on aeg 64840
How do i repair anti flooding warning sign
  • AEG Master
  • 17,130 Answers
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Posted on Jan 21, 2013
To lee_spensor6 ......great that worked a treat...tipping the machine and getting the rest of the water out deactivated anti flooding device.immediatley thanks..happy in Kerry (ireland) tonight
Posted on Nov 05, 2014
4 Suggested Answers
SOURCE: Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Posted on Nov 18, 2009
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Washing machine aeg 64840
Remove the line to the water level sensor, release the vacuum and it might solve. Also check inlet and drain blocks.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 20, 2013 | AEG Washing Machines
Aeg Lavamat 64840 programme stops at 1 minute to go. turning the machine off doesn't help and you can't open the door
Jul 10, 2010 | AEG Washing Machines
Got an AL4 error on my AEG 64800
al4 is tripping of anti flood float switch in base of machine. look for a leak mopping out the base resets the switch
Jun 19, 2010 | AEG 18 in. Favorit 64800 Free-standing...
Warning lights flashing for Anti flood system triggered and dishwasher not operational
The bottom "Y" 3 point hose at the bottom connected to main motor is of poor quality and does have 3 wire clamps. The hose does perforate and small pin hole causes water at the bottom to trigger the anti flood system with warning lights flashing and pump motor on ...
Dec 21, 2009 | AEG 24 in. Favorit 40660i Built-in...
Aeg favorit senorlogic three beeps and no evidence of problem but dishwasher won't work
Anti flood system triggered that puts the machiene in pump out mode. This machiene has a poor quality "Y" pipe at the bottom that is prone to pin holes in the pipe due to poor quality and extremely thin. The pin holes cause a small amount of water to activate the Anti flood micro switch on the polystireen float at the bottom of the washer.
Nov 22, 2009 | AEG 24 in. Favorit 40660i Built-in...
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Nov 26, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Washing Machines Logo
364 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
