Question about Kenmore 24 in. 15689 Built-in Dishwasher
Water not going to top shelf in dishwasher
Model #587.151.42400 will not get water up to the top shelf. can run but water is in bottom of dishwasher
Have you tried cleaning out holes in top rotor, especially the end ones?
Posted on Jan 26, 2009
AEG favorit 40850 dishwasher does not clean properly - help
under the top shelf or in the top of the machine is the water rotor. remove this and ensure none of the holes are blocked, also ensure your macine is not running on 1/2 half load as this may only activate the bottom. it should be set to full load to use both. if rotor bloackage is the problem use somthing to clear it. and also check the bottom one. also remove and clean the inner filter as debris may have got past it and getting pumped to your rotors.
I hope this was useful
Feb 15, 2013 | AEG 24 in. Favorit 40850 Free-standing...
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
There is no water that seems to go to the Miele dishwasher. After the cycle the dishes are as dirty as when they were in. Checked the filter, wanes-no problems.
Please provide the full model number of the dishwasher.
You need to check if water actually fills the dishwasher. Keep a cup right side up on the top shelf and run he dishwasher. At end of cycle check how much water is in the cup.
Aug 26, 2011 | Miele Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Top shelf not getting clean
It sounds like the hose at the rear of the top shelf has come unconnected. Pull the top shelf out when the washer is empty and take a look. If the hose has come apart you should be able to push it back together. Good luck with it.
Dec 27, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Dishwasher
basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Dec 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
101 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
