Service light on awo/r5206 washing machine
I just cleaned the pump on a awo/r5206 whirlpool washing machine and now the service light is on how do i reset it
  • Washing Mach... Master
  • 17,130 Answers
Resetting the washing machine: Follow these tips, click on: Reset
Posted on Jan 21, 2013
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
SOURCE: how to reset service ligth
whirlpool awdo/d 4505 flashing service light
Posted on Feb 03, 2011
whilpool awo/d 4305 light onclean pump can i do this myself
Posted on Nov 23, 2008
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
MY WHIRLPOOL WASHING MACHINE AWO/R5206 CONTROLS ARE NOT LIGHTING UP AT ALL. CHECKED FUSE IN PLUG AND FUSE BOARD NOTHING WRONG.
I am sure there is a electronic control board on the machine. I will bet the control board is defective.
Nov 26, 2014 | Whirlpool Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
I need to clen the pump on a whirlpool washing machine awo/d 4505
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Sep 22, 2009 | Washing Machines
Aug 06, 2008 | Washing Machines
Washing machine
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
660 people viewed this question
Top Washing Machines Experts
