Question about Samsung LN52a750R1FXZA
Samsung model ln52a750r1fxza start to power up chimes and then clicks off then repeats itself - unpluged and pluged back in just repeats without me doing a thing.
Had a similar issue with my set LNT 4061FX/XAA. After doing some research on line I found that Samsung company had an issue with some capacitors. There is a group action law suit. I found that my set was included. Called Samsung and they were extremely nice and helpful. They called a local repair shop, gave them a invoice charge #, and the repair shop ordered parts needed for me. I took TV to them (althought I was offered home repair), and my TV was fixed for "FREE"!!! Got it back and working better than it had in years!!!!! Thank you Samsung!!!!
Posted on Jan 21, 2013
  • Had a similar issue with my set LNT 4061FX/XAA. After doing some research on line I found that Samsung company had an issue with some capacitors. There is a group action law suit. I found that my set was included. Called Samsung and they were extremely nice and helpful. They called a local repair shop, gave them a invoice charge #, and the repair shop ordered parts needed for me. I took TV to them (althought I was offered home repair), and my TV was fixed for "FREE"!!! Got it back and working better than it had in years!!!!! Thank you Samsung!!!!
lukster
  • 217 Answers
SOURCE: clicking and color threads
probably a pinched cable inside or the power supply is bad
Posted on Jul 20, 2008
  • 6 Answers
SOURCE: I have a Samsung 52
easy fix. check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Posted on Sep 01, 2009
dave1645
  • 834 Answers
SOURCE: Turns itself off and clicks back and fourth.
you have a power supply issue sound like bad capacitors they will be puffy on the tops and need to be replaced
Posted on Sep 22, 2009
  • 610 Answers
SOURCE: my samsung 40
power supply board has failed. call 1-800-samsung for nearest service center. VERY common problem.
Posted on Dec 01, 2009
  • 927 Answers
SOURCE: i have a samsung lnt4042h and it has worked fine
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Led 55 in 3d samsung 240 hz smart tv keeps freezing
FIXED!!..I had the same problem. Power board looked fine (not blown capacitors) It started after a moving...it was just faulty (loose) connectors from the powerboard to the mainboard..... I just unplugged and plugged them back firmly. db2f651f-d050-4b58-b50a-79ef9a8650f9.jpg
Feb 19, 2013 | Samsung UN55B8000 55 in. LCD HDTV
My Samsung TV LN52A750R1FXZA is Power cycle on its own
Sounds like a bad main board, but you will need to have the set diagnosed to make sure.
Aug 12, 2012 | Samsung LN52a750R1FXZA
I have a 46 inch Samsung flat screen LCD. 3 years old. 500 series. When I turn it on-press the power button-It keeps clicking like it is turning on and off repeatedly by itself. It clicks on and off...
Before researching into a technician repairing the tv, you should see if your firmware is up to date. Typically you can access the menu look for an option that says tv information or about tv. There it should list the firmware version. Check this version against the latest version on Samsung's download website, http://www.samsung.com/us/support/downloads/
Here enter your model information and you can download the latest firmware to a USB stick. Samsung should also provide instructions on how to install this firmware. If you have any questions come back : )
Jul 18, 2011 | Samsung Televison & Video
I hit the remote on button the 52"samsung tv
Tries tv unplug,replug it back like about an hour later.For the tv to resetting itself back to the factory setting,it should be working again.If it is still have the same problems,the causes mostly the power supply board have the problems,that the board where the power a/c cord plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Mar 21, 2011 | Samsung Touch of Color LN52A650 52 in. LCD...
Turning off the on/of chime for a samsumg series 5
In SETUP you will see.
Melody → Off / Low / Medium / High
# NOTE - If this info was helpful to anyone please click on yes!
Jun 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Clicking and color threads
Jul 12, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN52a750R1FXZA Logo
311 people viewed this question
Jerry Greenberg
Jerry Greenberg
