Question about Sewing Machines
Screw fell into machine when taking off needle plate. Can't open machine to retrieve the screw.
ginko
  • 19396 Answers
SOURCE: Needle keeps falling out of Pfaff Creativ 2170
Check that the metal plate under the needle is properly fixed into the machine.
If the needle is hittling the plate, it can get stuck and fall out.
If the needle keeps getting out then the small pin that keep the needle is broken, you will need to take apart the machine to fix this.
Posted on Sep 14, 2008
Zenqi
  • 208 Answers
SOURCE: I have a Bernette 50 sewing machine....i was
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Posted on Jun 27, 2009
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
SOURCE: I need a manual for a White 2200 multi- tasker sewing machine.
You need to take this to a repair person.
I do have a manual but you can go to www.whitesewing.com and get one. Also the tension is a big problem if you don't use the exact bobbin. I was told that most bobbins will work in this machine but it turns out that only the one that comes with the machine really works. I would look for the parts to your machine. Sometimes they get lost in your sewing kit.
Posted on Nov 15, 2009
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
Posted on Feb 13, 2010
I dropped a screw down the throat of the machine. How do I get it out?
Lift the machine, turn it upside down and shake it. That's how we do it here in the shop.
Jun 28, 2014 | Brother PC-420
How do I remove a stuck bobbin casing from a Bernina sewing machine?
Is it a drop in bobbin machine? If so, take off the needle and the needle plate (=throat plate), and you should have clearance to pull it out. If it's a vertical bobbin machine, taking off the needle plate may buy you the extra clearance you need to get things out again. Sometimes a drop of sewing machine oil every where you see a potential "bind spot" can help. Just mop out the excess oil after you've retrieved the bits that fell in.
Jun 02, 2014 | Bernina Sewing Machines
Needle clamp tragedu
The needle clamp usually has a screw on the back that is tightened to prevent the needle holder from falling off. The screw on the back should be very loose. Place the holder on the arm (moves when you rotate the wheel by hand) with the screw towards the back and the hand screw on the side. Tighten the screw in the back and it shouldn't come off. Now, place the wire on the side where the hand screw on the inside of the hole along with the arm and place your needle in. Now you can tighten.
Apr 27, 2013 | Sewing Machines
My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Jun 07, 2012 | Singer Confidence 7467 Mechanical Sewing...
How to remove the Elna needle plate?
very gently use a butter knife or a flat screw driver to try & lift up the needle plate, do not use a lot of force
May 29, 2012 | Elna Sewing Machines
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
The needle on my sewing machine literally just fell off. Not kidding. I'm holding an unbent and otherwise pristine needle. Oh brother SE-270D! I'm not sure how to put the needle back in. I think it just...
when you put the needle in the needle clamp holder the flat side of the needle goes toward the back of the the machine when you tighten the needle clamp screw make sure it's holding the needle,,make sure you can't pull the needle back out of the clamp,, if you can something is wrong with the needle clamp or the screw
Dec 06, 2010 | Brother SE-270D Computerized Sewing...
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
Jun 27, 2009 | Bernina Bernette 75
I have a Husqvarna Emma sewing machine. The needle broke and a piece is under the bobbin holder. How can I get under the bobbin holder?
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Apr 18, 2009 | Husqvarna Viking 1
Need to get needle that I dropped into the sewing machine shaft.
If you don't want to take it to a "repairer" then I would suggest that you remove the screws and open up the machine to retrieve the needle. Just be mindful of where you removed the screws from i.e. the size as there may be several different sizes.
Sep 22, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
