I can't access wifi networks the wireless internet connection got deleted so how can u help me
  • Computers & ... Master
  • 27,725 Answers
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Posted on Jan 20, 2013
  • 53 Answers
SOURCE: Laptop cannot connect to internet outside company domain using wifi at home
typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Posted on Nov 06, 2008
jmassengill
  • 345 Answers
SOURCE: Wireless Connection Good but PC Often Can't Access Internet Sites
I would scan the computer for viruses.
Posted on Nov 09, 2008
  • 100 Answers
SOURCE: wifi is connected to a
It is possible that the router is not properly connected to the ISP line. check the line from the router to phone line. usually there will be light on the router indicating that the router is succesfully connected to the ISP and sending and receiving data . Sometimes simply powering off the router for 1 minute , disconnecting the cable from the phone line, then powering up the router and then reconnecting the line to the phone will help.
Posted on Dec 19, 2010
dddriver
  • 107 Answers
SOURCE: i can't access any wifi
on the front of your laptop is a switch. This switch is for turning wireless on and off for areas like airports or just for security. Frequently, your thumb or whatever clips it and suddenly you have no wireless. Flick the switch to the one where there is computer with brackets on each side. good luck!
Posted on Jun 13, 2011
  • 4961 Answers
SOURCE: eurostar epad internet connection problem
Do some scans for viruses and malware. You can get some great FREE anti-malware and antivirus software here:
http://majorgeeks.com/download.php?id=31&sort=7
Posted on Jun 27, 2012
What are wifi benefits?
The benefits of wifi are as:-
1. It will be cost effective.
2. Can able to connect many wifi device.
3. It provides the wireless service.
4. You can increase the expandability of internet.
5. By using wifi it helps to provide the internet to other devices.
6. You can provide the wifi service securely to other.
7. Making wifi hotspot marketing increase the usability of wifi.
Jun 09, 2018 | Computers & Internet
Router connects to computer fine but can't find network, network is running
Can you do me a favor first? if this is possible, please connect your computer with cable to the router and from the router to your modem or wall port for internet. See if this gives you internet.
Second, see if other network devices can access the internet with this wireless internet connection. Try this one first then the Cable.
I want to know where the problem is. If you say like for example Cable works, but other devices with same network wireless access doesn't work. Then i can say that wireless is either bad configured or something else happening with wireless. Then i can continue to help you.
I'm an IT student who works specially with Teamviewer to access peoples computer to help them fix such issues when it's possible and needed.
Checkout here for more netwoking accessories online , http://www.gizga.com/consumer-electronics/computer-and-networking
Jan 27, 2014 | PREMIERTEK PowerLink Hermes IEEE 802.11n...
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
How to install my router for wireless internet on my laptop.
1. Purchase a wireless router that fits your needs and price range.
2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7. Click on "Properties."
8. Select the "Wireless Networks" tab.
9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10. Click on "Configure" when you see your network's SSID in the "Available Networks."
11. Enter your network's SSID and WEP key.
12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Thanks.
Have great day.
Oct 01, 2010 | Computers & Internet
I dont know to use wifi in LENOVO 3000 Y410
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Cannot connect to internet with konaki netbook
    How to Connect a Laptop to a Wireless Router Using a Windows Operating System
    Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    Dec 12, 2009 | Computers & Internet
    Computers & Internet Logo
    64 people viewed this question
    David Payne
    David Payne
