Question about Cameras
What sd card should work - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Any camera designed to work with SD cards should work with any SD card, 2GB or smaller. Some of them will also work with higher-capacity SDHC cards as well, some won't. Do you have a particular make and model camera in mind?
Posted on Jan 20, 2013
Camera says insert an sd card when I already have one. will not let me take pictures
maybe the problem is in your SD card, try to used another SD card. and check if it works.
Feb 14, 2014 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Camera fails to acknowledge memory card
Try cleaning SD card connectors with clean rag, and blow some dust out of a SD card connecting place, if it doesnt work try checking that SD card on some other camera, if it works take your camera to service, if SD card doesnt work on othar camera than SD card is broken.
Feb 16, 2013 | Kodak EasyShare One Digital Camera
On model MFH-DGW2.1 it will not work with sd card. it will not recongnize card, i can not get it to change modes or get camera to work. take card out and camera works
SD card 101: the 2.1 MP cam is not compatible with newer sd cards...get standard SD class 4 or less; SDHD(high def);SDHC(high capacity);and classes above 4 may not work(class 4 SD cards usually have a 4 stamped just under the SD on card's label.
Aug 07, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a digimax 4010. Do I get a 2mg sd card? What is the diference between a sd card and a sdhc
SDHC is an extension of the SD standard that extends the capacity from 2GB to 32GB. It's backward compatible in that devices designed for SDHC cards will also work with SD cards. It does not go the other way---that is, SDHC cards will not work in devices designed for SD cards.
I presume you mean a 2GB card, since a 2MB card might hold one picture.
The Digimax 4010 works with SD cards, not SDHC cards. You may use an SD card. Just make sure it is an SD card, 2GB and smaller. SDHC cards start at 4GB and go up to 32GB but, as stated earlier, will not work in the 4010.
May 25, 2011 | Samsung Digimax 4010 Digital Camera
When i go on the sd card to play games, It says "an error has occured. Press and hold the power button to turn it off. Please the Nintendo operations manual for help troubleshooting? PLease help, I...
Is this a Nintendo Wii? If so, not all games will work directly from the SD card.
If the console shuts down straight away just by accessing the SD card menu, then it's probably just the SD card itself causing the problem.
Make sure you are using the correct type of SD card. Also, make sure you have no corrupt files (i.e. music, photos, pirated games). here's some information Nintendo have posted themselves regarding SD card compatability:
Not all SD Cards are compatible with the Wii console. Please read the following:
  • The Wii console is only compatible with SD Cards that are 2 GB (Gigabyte) or less. Cards with a capacity higher than 2 GB will likely not work with the Wii console.
  • SD Cards with a slow speed may experience slow transfer time when loading files, or may not work at all. Slow transfer times can also occur with SD Cards that have a great number of files on them.
  • While any SD Card with the above specifications may work, Nintendo has licensed specific SD Cards for use with the Wii console. You can identify these cards by the Nintendo Seal on the packaging of the SD Card.
Mar 05, 2011 | Computers & Internet
I can't get my sd card to work in the computer. Do I need something to make it work.
No you don't need something to make your sandisk(sd) card to work when you place it in the sd slot of your computer, now if your sd card is a hc or high compacity card then it would not work because the sd card reader is not new upgraded enough to the point of reading the hc cards if its not a hc card then your sd card reader may be broken you can buy a good new sd card and more port hub to work on your computer but i would check first if it is your card not the card reader.
Feb 10, 2010 | Computers & Internet
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
