Question about Honeywell Furnace Gas Valve Sv9501h2409
We jumped the high limit switch and now everthing stayd on except it wont stay lit
We have cleaned all we can, we have a solid lit light and now we have jumped the high limit switch. everything will come on and stay on but flame wont stay lit
  • 52 Answers
There might be a sensor in front of the burners. Looks like a metal rod. Make sure power is off and carefully use a wire brush to clean the rod. It will only have 1 wire to this sensor.
Posted on Oct 20, 2013
I have a Reddy heater RLP100. It will light easily but will not stay lit when you let off pilot
It's either the thermocouple or the limit switch on back of burner, disconnect coupler and jump the 2 tabs. if it works thats the problem if not it's the limit switch.
Feb 21, 2015 | Reddy Heating & Cooling
Raypak gemini 53 pool and spa heater pilot iights but burnner wont ignight
The thermocouple allows the pilot to stay lit. If your burner will not light but the pilot is lit, there is a problem with either the control or the control valve. Either the signal is not being sent to the control valve to open or the signal is being sent and the valve is faulty.
Jan 08, 2015 | Raypak Pool & Spa
Jandy Lite 2 Pool Heater won't stay lit
This could be a number of things, high limit switch, temp sensor or clogged burners. If the heater does not get much use cob webs could be the culprit. To test the high limit switches you can disconnect them temporarily and use a jumper wire , if it fires and stays lit then you have found your problem. Just disconnect the 2 wires , and use a separate wire to connect the two together bypassing the switch. This is a safety feature and should only be jumped as a diagnostic tool and not left to operate this way.
Dec 06, 2013 | Jandy Pool & Spa
My heater is in lockout according to the 2 flash code I'm seeing. My tank is half full so I no it's not a supply problem, and it has worked in the past. It tries to fire but it won't stay lit. It will go...
clean the flame censor check connection from sencor is tight, try jumping out the limit switch high leval , or the pressure switch see if it lights then
Jan 16, 2011 | Mr. Heater MHU45LP
Pilot wont stay lit
If it will not stay lit from a cold start, you will need a thermopile. You can check it if you have a DC meter that will test milivolts. It should be putting out between 300 and 500. If it will not stay lit after the pot gets hot, you will most likely need a high limit. Try pushing the red button below the thermostat. This will reset the high limit.
Oct 04, 2009 | Pitco Frialator 45C Deep Fryer
Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward Comfortzone pool heater pilot will stay lit but main burner will not fire. If the TH terminals are jumpered it will, but it won't stay on.
Have you tried jumping the pressure switch, as well as the on/off switch. sounds like something in the safety circuit is open
Jun 10, 2009 | Hayward Comfort Zone Electric Spa Heater...
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Honeywell Furnace Gas Valve Sv9501h2409 Logo
140 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
