Question about Nordic Track NordicTrack T5.7 Treadmill
Nordictrack t5.7 wont start
Keypad stuck
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Adjust the REED switch, see the diagram, clean itm , test for open or faulty, and tight the connector,
2) replace the old batteries by new ones, clean the contacts batteries very well.
3) tight the ribbon cables for keypads, and clean ti
Posted on Jan 21, 2013
Nordictrack c2500 treadmill troubleshooting
you must tight the ribbon cable and clean it. 2) clean the keypads from dirty, corrosion, and oxide. 3) adjust the REED switch see the diagram attached, clean it, and tight the connector very well.
Jul 21, 2013 | Exercise & Fitness
Nordictrac 1750 stuck in download files mode..
you must restore to the original factory, and see was happening.
Ohterwise the software can be corrupted.use antivirus+antimalware
God bless you
Jun 14, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Console buttons dont work, deadman key removed goes into demo mode...
Adjust the REED swicht , see diagram, clean it, and tight the plug very well.
2) clean the ribbon cables, for keypads, clean it.
3) tight the connector from display board vs lower board too
see the block diagram
After you fix it. RUN the software calibration for diagnostic, troubleshooting. too
God bless you
Oct 10, 2012 | NordicTrack Exercise & Fitness
I have a Nordictrack Reflex Sr. The console turns on but the treadmill only runs when quickstart button 5 and 11 are pressed. also incline not working
1( Adjust the Reed switch, clean and tight the wires connector very well
see the diagram.
1A) Tight the ribbon cables from keypads very well, and clean
2) Run after you fix it the software calibration for diagnose and troubleshooting, and fix it.
See the block diagram
Jun 14, 2012 | Nordic Track Nordictrack Apex 6500 Reflex...
No communication from start stop buttons. cannot get into calibration mode
you must adjust the REED swith, see the diagram attached, clean, and tight the wires connector very well,
Tight the ribbon cable from keypad verywell, and tight the connector from display board vs lower board.Clean the keypad with special spray contacts.
After you fix it. RUN the s. calibration.
God bless you
May 22, 2012 | Nordic Track NordicTrack T5 zi Treadmill
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
Display turns on, manual mode, but beeps (4 times) every time I touch a button, it will not start up to run correctly
Press the Stop and the Speed Up keys down while inserting the safety key this should get you in to calibration mode. If not then you possibly have a keypad/upper electronics failure and depending on cost will need replacement.
May 31, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack T5.7 Treadmill Logo
230 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
