Problem with washing maschine temperature control knob
I over turned my washing maschine's temperature control knob, so now its on the 90 degrees celsius. Do I have to replace whole control panel or just that knob?
  • Washing Mach... Master
  • 17,129 Answers
It depends on whether the knob is slipping or that the contacts are working within. Please check and see if the controls can be moved further and the temperature cuts off earlier than 90. If so the control and the thermocouple is working and the external knob needs to be replaced
Posted on Jan 21, 2013
blueextc3221
  • 15935 Answers
SOURCE: Hello Advisors, I need real help
The hot water should be as hot as the inlet temp water.
170degrees. There is no internal heater to increase the water temp.
Please check that the hot water supply valve is turned on.
Check the hot water inlet hose is not kinked.
Also - remove the hot water hose and make sure the shipping plug from the hose hookup was removed.
If the hot water supply is on, and there is verified hot water coming from the hose (into a bucket) it will be time for some warranty work - as your mixing valve solenoid (hot side) has failed.
Thanks for using FixYa!!
Posted on Jun 05, 2009
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
keemo68
  • 1263 Answers
SOURCE: Control Panel Installation
in some instances there is either a set screw(generally a small allen head) or a small pin that has to be forced out. these keep the knob from spinning on the shaft and stripping it.
Posted on Aug 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: I need to know where I can find the timer module
Post your model number for a more specific answer.
Please rate this answer.
Posted on Mar 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: how do you access the control panel
The topside control panel has four small torx screws that hold the control panel to the rear. The timer has a small U clip under the knob that needs to be removed with needle nose and then the knob comes off so the timer can be replaced. I have your washer's training manual HERE
Posted on Apr 20, 2010
How do i reset code F21 to a Bosch Maxx 7 washing maschine?
Turn knob to 12 o'clock position
turn to 6 o'clock position
press an hold the spin button
turn knob to 7 o'clock while still pressing the spin button
let go of the spin button after 5 seconds
turn the knob back to 12 o'clock
assuming you have repaired you're f21 motor issue it should behave its self
Mar 27, 2015 | Bosch Washing Machines
Why does hotpoint maschine, only 15 days old, suddenly shrink wool clothes?
I was under the impression that only HOT water will shrink wool clothes. Did you buy mistake set or forget to set your temperature setting. Think back to the previous load that was washed. This may be the reason for your shrinkage problem. GOOD LUCK FRIEND.
Feb 25, 2015 | Hotpoint Washing Machines
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
How di i remove the agitator from a GE washing maschine?
i can remove the top of the agitator but the agitator its self.
May 12, 2012 | GE WJSR2070B Top Load Washer
The temperature control does not change when the fan is turned up. if i want to change the temperature from hot to cold, i have to turn down the fan, listen for the switch in the dash and then turn the...
I can tell you about my experience on my 1999 F150. I do not believe it is the blower control switch because mine went out and only affected the fan speed. On my truck, in an incident like yours, I could not get a good response from the temperature switch.
I would turn the control and it would hit a stop on both ends, but the temperature would not change to match the switch. What I found is the stem of the temperature control did not turn because the knob cracked behind the switch. There is a half-moon shaped metal clip inside the plastic temperature knob. The clip can spin when the knob is cracked and nothing moves right.
Because the plastic knob has molded stops under the knob, from the drivers point of view, the knob was turning lock to lock. In reality, the stem was not turning. Try taking the knob off and turning the stem with pliers wrapped in cloth to protect the plastic. Then see if the temperature changes.
Jun 30, 2011 | 1998 Ford F150 Regular Cab
AC & Rear wiper switch button indicator lights blink
The procedure for re-setting the HVAC control panel on a 1998 Dodge Grand Caravan follows:
With ignition on but not running
1. turn knob to air vents
2. turn fan knob to ON
3. temperature setting on COLD (2X) {I have dual temp controls}
4. hold top(rear wiper) and bottom (rear wiper with wash) buttons pressing down together until all the buttons cycle through (this will require 1 to 2 minutes of continuous pressing)
I learned this from a very helpful local Dodge service adviser
May 09, 2009 | 1998 Dodge Caravan
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
