Question about Epson Stylus Photo 1410 Series
I get noise in the dark earies whine i use glossu paper
  • 542 Answers
You should check that you are using compatible ink for the printer that you are using and that you are selecting the correct paper type in the printer properties section when printing.
Posted on Feb 01, 2013
Model i90. Begins to feed paper then stops and has a loud whining noise
Paper is jammed in the feeder and the loud noise is the feeder trying to do its job.
Apr 25, 2016 | Canon PIXMA Office Equipment & Supplies
Ac makes whining noise on a 2004 Pontiac grand prix
Is the whining noise coming from the engine compartment where the compressor is located or is the noise coming from inside the car? If the noise if coming from inside the car it could be your blower. When a blower wears down the bushing is the first thing to wear down and it begins to have play. That makes the blower/fan vibrate making a loud whining noise. Replacing the blower could solve that whining noise.
If the noise if coming from the AC compressor, it also could be a bad bearing within the compressor.
Feb 23, 2015 | Pontiac Cars & Trucks
Engine whine acceleration
easy one, not moving , no fun getting killed finding it moving, LOL
sorry for dark humor.... bet I do , this.... with instruments.
so its not moving
the hoods open
i find the source of any noise with 2 tools'
one is free. a rubber hose to ear. listen find source
or
the $5 harbor fright(pun) stethoscope, i probe and find who and what
is singing.
tranny?
clutch.
engine,
accessories on engine.?
is the ISC making now noise
you can probe (steth) the alt, the p/s and a/c compressor.
you can probe front and rear and hear the bearings purrr... (normal)
or scream (bad)
i have a steelman sonic ear.... that can find anything, but U-joints.
Dec 23, 2013 | 2008 Honda Accord
Why is blower motor making whining noise when on?
The bearings are shot. You have to replace it.
Nov 12, 2013 | 2002 Honda Accord
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Whine from 2005 corolla automatic transmission
Have the tranny serviced with fluid change and filter, if noise it still there it is the torque converter . Have the dealer fix it ,and have it on paper with dealer invoice when it is done. Do all this before warranty expires. IT IS NOT USUAL for any car, Toyota included, to have tranny whine!!!!!
Jan 23, 2010 | 2003 Toyota Sienna
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Hln43w. Screen went dark. 3 lights on front flashed, and TC emitted a high pitch whine. Replaced lamp. 3 lights no longer flash, but whine is still present and screen is still dark.
if there anything like commercial flourescent cieling lights, there is a unit called a ballast which may be responsible for the symptoms you are observing.
May 29, 2008 | Samsung Televison & Video
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
Computers & Internet Logo
41 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
