Question about Hobart Welding Tools
Hobart engine drive welder has no power out put
I have a hobart 225 engine drive welder the last time i was trying to use it i couldnt get it to strick an ark or even the generator part wouldnt put out power to run my grinder
what things should i check to see if they work and how do u check them
please help
dave
    Problem Solver:
  • 7 Answers
I took an old trickle battery charger,6 volts and energize the armmiture,all so called polarizing,google it ,shows how also
Posted on Feb 04, 2009
HAYeeee SUPERDAVE13:
Run a wire from the + post of the starter battery and touch the other end to one of the contacts of one brush. Try to strik a arc. If no arc, touch wire to other brush lead. Hold this wire on brush lead for around 5 seconds. The brushes I'm referring to are/would be the smaller ones on the "exciter". The exciter lost it's magnetism. Now, there maybe a wire running from the alternator already in place. The brush would get its juice from the alternator. In tracing the wires from the alternator, it may go to a little square electrical device. This devise, about as square as a postage stamp, tricks the AC from the alternator into thinking it is DC. It is this little device that needs to be replaced. The welder will not operate untill there is "Excitement" from the exciter. Also there will not be any juice to your 110 electrical outlet..... I have a HOBART MEGA ARC 400 and need to replace that little device on mine. Everytime I use the machine I need to "excite" the exciter in the way I described.......Cowboy Bob
Posted on Mar 04, 2009
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Nov 21, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Can i power this unit with my old Miller Bobcat 225. Also what gun do you recommend?
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
Dec 21, 2010 | Hobart Welding Tools
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
My Hobart Handler 120 needs a .045 wire drive wheel. Where can one be purchased?
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
Dec 26, 2009 | Hobart Handler 140 Mig Welder
I am looking for Hobart parts I think???
you can go to any welding store(praxair,air gas)and they will be able to order the parts you request,need to get all the imfo.you can off of welder for them to be able to help you.
Jun 09, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Welder will not power auxillary outlets
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
Mar 28, 2009 | Hobart Welders 500433 Champion? 10,000...
Welding Tools Logo
858 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
