Question about Delphi Knock Sensor Chevrolet Corvette 95 94 93 92 Camaro 91 As10133
2005 Pontiac Grand Prix 3.8L with a P0327, replace knock sensor?
  • 1,975 Answers
There are some testing procedures that should be done to fully diagnose the diagnostic trouble code (DTC) of P0327. The part you can probably get after market for around 40 to 50 dollars. If you want tp take the chance and go ahead and purchase one you can try. Most likely that's the problem but there may be an open circuit. That would be up to you though. You have 2 knock sensors in your vehicle. The DTC of P0327 happens to be the easy one of the 2. Below is a picture of the location of the one your DTC is refering to. Hope this helps....
2005 Pontiac Grand Prix 3.8L with a P0327, replace - 1_21_2013_12_04_42_pm.jpg
Posted on Jan 21, 2013
I have an 08 grand Prix the knock sensor has gone bad (bank 2) it's in between the engine and transmission, is it possible to replace it without removing the transmission?
What code did you pull ? How do you know it's bad ?
Remove the transaxle. Refer to Transmission Replacement for the 4T65-E transmission. Drain the cooling system. Refer to Cooling System Draining and Filling . Remove the bolts (2) from the knock sensor heat shield (1). Disconnect the knock sensor electrical connector (3) from the knock sensor.
Sep 14, 2016 | 2008 Pontiac Grand Prix
Why is error code p0327
Code P0327 indicates that the readings from the #1 Knock Sensor circuit are too low, is outside of its operational window and malfunctioning. Symptoms
  • Check Engine Light will illuminate
  • Engine pings on accelration
  • Engine may be running hotter or colder than normal
  • In rare cases, the engine may not exhibit noticeable symptoms
Common Problems That Trigger the P0327 Code
  • Defective Knock Sensor
  • Defective Knock Sensor Circuit or connections
  • Defective EGR System
  • Malfunctioning Cooling System
  • Rich air/fuel ratio
Common Misdiagnosis
  • Knock Sensor replaced when cause of code P0327 was a cooling system problem
  • Knock Sensor replaced when cause of code P0327 was an EGR system malfunction
Sep 28, 2015 | 2005 Suzuki Forenza
1990 grand prix 3.1 computer code 43
engine code 43 - electronic spart timing problem- possible knock sensor problem.. check for 5v at knock sensor wire.. if it has 5v then probably need a knock sensor.
Apr 12, 2010 | 1990 Pontiac Grand Prix
1999 pontiac grandprix knock sensor ,low input bank2 what do I do
There is only 1 knock sensor on the engine. Check the connector first, and make sure you are running a decent grade of gas. You may need to replace the sensor if all else is okay
Jan 14, 2010 | 1990 Pontiac Grand Prix
2005 pontiac grand prix. Replaced the motor car wont start. Replaced cam sensor and the crank sensor. Car gets fuel but no current. Still wont start
check at the coil pack if all connector where plugged, i think there is 3 connectors to plugged
do you have voltage at the coil module
Aug 19, 2009 | 2005 Pontiac Grand Prix
Diagram of 3.4 DOHC Motor online
Both knock sensors are screwed into the side of the cylinder head between the front 2 cylinders.
Jun 22, 2009 | 1996 Pontiac Grand Prix
Delphi Knock Sensor Chevrolet Corvette 95 94 93 92 Camaro 91 As10133 Logo
580 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
