Question about Electrical Supplies
Hanwo hde 5000 E generator wiring diagram
Wiring diagram
2 Suggested Answers
  • 512 Answers
SOURCE: need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Posted on Oct 02, 2012
Testimonial: "Thank you very much."
Need a wiring diagram for a onon marquis 5000 generator Model# 5bgmfa26105f Serial#c953351341
Neither are available at cumminsonan.com but you might contact them for more info than is contained in these two manuals:
http://www.cumminsonan.com/www/pdf/rv/f-1123.pdf
http://www.cumminsonan.com/searchresults?search_text=marquis
Oct 04, 2012 | Electrical Supplies
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
My kohler 5000 generator will not run unless I keep the starter button depressed
First thing to do is get a "Wiring Diagram" for your Unit.
Once you get the diagram, just Follow the DC Ignition Power path from
the Battery, on thru to the Ignition Coil. Somewhere you aren't getting
12Vdc to the Ignition Coil, UNLESS the Start Switch is in the Start Position. It shouldn't take longer than about a hour, with a VoltMeter to find where the circuit isn't being "Made", and fixing or replacing that part. More solutions to different engine and generator problems at http://solosmallengine.blogspot.com/ and http://solo.ecrater.com
Jun 07, 2012 | Electrical Supplies
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
Need onan marquis 5000 model 5bgmfa26105f wiring
Give me to full model and spec # and I will email you a service manual.
Nov 04, 2009 | Watts Onan Portable Generator - 5000 ,...
No electrical output
probably your AVR card is burnt...
an AVR card is located right outside the stator...looks just like an AK-47 clip (i don't know how else to describe it)...i put a pic below this.
replace it and check again
466fecd.jpgAVR location
168ff0f.jpgAVR card
Dec 28, 2008 | Electrical Supplies
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
60 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
