Question about Whirlpool WTW58ESVW Top Load Washer
Washing machine will not turn on
Used the washing machine yesterday. Heard water go into machine, but noticed a bit later that nothing else was happening. Able to remove water by moving to spin cycle. However, now the machine will not go on at all. Please help. I have no idea what to do.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
First, check to be sure the door lock is securely fastened and the door is locking. Post back the results.
Posted on Jan 21, 2013
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Posted on Oct 14, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
Hotpoint wf320p washing machine leak
pull the plug
check the pipes from the soap dish to the tub
Feb 09, 2014 | Washing Machines
Washing machine will not switch on
I think you washers control board has go south, caput etc.
Jul 14, 2017 | CDA CI592 Front Load All-in-One Washer /...
After a load is finished and drained properly, several hours later the washing machine has filled with water again. I then have to run a drain cycle to use it.
This sounds like the valves that let the water in are leaking, just a little bit. Over several hours, they leak enough to be noticed.
You can have those valves replaced, or you could shut off the water going into the washer with the valves in your water supply. (the one's that are usually right next to where your hoses connect)
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
I bought a used washing machine yesterday from a friend. We installed it together and I noticed sudy water leaking from the front and back of the bottom of the washer. He said he hadnt used them for a...
If it set for a long period of time, then the main tub seal may have gotten dried out. Storage is hard on items like seals and belts. It may swell some and seal itself with some use, but there is no guarantee that it will. Hope this helped.
Jul 16, 2009 | Washing Machines
The washer just stopped pouring water. Only faint humming sound.
Cool!
How 'bout a FixYa for the effort, and let me know if you need anything else.
Feb 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Open Questions:
See all Whirlpool WTW58ESVW Top Load Washer Questions
Whirlpool WTW58ESVW Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
