Hotpoint tdc62 thermostats keep breaking
Works fine but no heat. Replaced thermostats twice now within two weeks and the heat has gone again, presumably thermostats again? Ive cleaned all the vents etc to make sure theres no fluff. What could be the problem?
  • Debbie Jarvis Jan 20, 2013
    This is a condensing tumble dryer not a washer.
  • Debbie Jarvis Jan 24, 2013
    I don't really know about wiring etc. but I connected the wires together to over ride the thermostats - the heating elememt came on but only half of one of the four bars worked. Would this cause the thermostats to break and what would cause the heating elements not to work? Is this fixable?
  • Washing Mach... Master
  • 17,130 Answers
It cannot be that the thermostat fails unless there some fault in the circuit or wiring . You need to recheck the lines to the element and the thermostat from the controller., check if there is any leakage or cross connection. Also it is possible that the loss of heat is due to faulty harness or wiring or connectors. Remove and plug back all leads and connections.
Posted on Jan 21, 2013
  • 3600 Answers
SOURCE: Dryer not getting enought airflow to outside dryer vent
Normally it is six feet and not more than two bends, if it has been doing this you have buildup in the ducts and need to clean the ducts. I would suggest you make a new hole to address the problem. Also if you have a plastic pipe sometimes they develope a flap those blocks or slows the air down you can’t see this unless it is in dry mode. Any blockage will slow the air down allowing particles to drop down and gradually plug the vent, if the bends are too tight it to will slow down air flow and cause the same thing I suggest you cut the length of the hole to stop this problem if you can, it is not hard to do and I can give you the instructions if you post here.
Posted on Sep 03, 2009
Testimonial: "Very helpful information and quick reply. "
  • 464 Answers
SOURCE: No heat, no flame, temperature based high heat
if the dryer doesn't shut off you need a new timer. have you replaced the igniter or glow coil? it needs to glow white not orange in order to ignite the gas.
Posted on Oct 11, 2009
apart4u
  • 213 Answers
SOURCE: Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
SOURCE: locating fluff filter on aeg washer/dryer
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Posted on Mar 14, 2010
  • 6277 Answers
SOURCE: Hotpoint Front loading Aquarius WF210 Where is
Same again!
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint TDC62 drying clothes ok but not cooling down at end of cycle
I would check the cycling thermostat, the hi limit, the moister sensor, control board lastly
Mar 21, 2015 | Hotpoint Dryers
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
I have a hotpoint tdc62 when on it works fine apart from a grinding noise when the drum is going round could it be the belt? its 5 years old never been changed many thanks
More than likely worn rear drum bearing or worn front bearings.
Remove the rear panel, and you should see the drum shaft, check for wear here.
Jan 15, 2010 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint condencer dryer TDC62
Several reasons for it not to heat.
Obviously faulty heater, and or thermostat(s). You need meter to test. Heater and stats are located at the rear of the m/c behind a removable panel.
Faulty programmer, faulty heater relay.
Check filters etc, refer to instructions for this.
Plz leave feed back on this .
Thanks.
Dec 12, 2008 | Dryers
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
your thermostats have most likely gone they are situated at the back of the machine on top of the heater
Feb 09, 2008 | Hotpoint TDC32 Electric Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
