Question about Novatel Nova Development Berlitz Italian Premier Full Version for PC, Mac
No Immersion Environment for Berlitz Learning System
Berlitz Learning System Premier (Italian) cannot find multimedia files for Immersion Environment, which means that the whole Immersion Environment will not work. The program comes up, but when I click on Enter Immersion Environment I get a window headed "CD Drive for IEO693D," informing me that "the multimedia files for this Immersion Environment" cannot be found.
I purchased the Berlitz Italian program in the spring of 2008, and for several months it worked perfectly, and then it suddenly stopped running properly. I've tried everything, including a couple of phone calls to your help desk, and including numerous re-installations of the program (after removing all parts of what was there on my computer). My operating system is Windows XP.
My wife and I are going to Italy in June, and I would be most grateful if you could sort out this problem for us so that we prepare ourselves by using our Berlitz program fully.
Many thanks,
Jonathan Wisenthal
  • 15 more comments
  • jwisenthal Feb 01, 2009
    The problem persists when I have the CD in the drive.
  • jwisenthal Feb 02, 2009
    I have downloaded and installed Flash Player 10.0.12.36, but the Berlitz problem is still there.
    Note to Wiz: Is there something missing in your posting?
  • jwisenthal Feb 08, 2009
    I have installed Directx and the Berlitz Italian still won't run with the Immersion Environment. In fact, at the moment, I can't bring up Berlitz Learning System at all.
    The Berlitz link won't work: "The page cannot be found."
    In order to copy the error message I will have to reinstall the Berlitz software anyway (because it won't come up at all at the moment), so I would welcome advice about how to use a different folder when I do so.
  • jwisenthal Feb 09, 2009
    I have looked at transitionsabroad, but I'd still like to follow the suggestion of re-installing the Berlitz program into a new folder, and I'd welcome advice about just how to do this.
    The programs that were running when the computer started up were Kodak Softward Updater Agent, Corel Calendar, Windows Instant Message (or some such name).
    The hard drive's total size is 74.5 GB, and the free space is 58.4 GB. I'm not sure how to identify the computer's memory.
    The error message on Berlitz is as follows:
    CD Drive for IE0693D
    Berlitz Learning System cannot find the multimedia files for this Immersion Environment. Those files may be on CD or installed on your hard drive.
    If you did not install the multimedia files for this Immersion Environment onto your hard drive, you must put the correct CD in the drive to hear sound and see video. If your Berlitz System program has more than one CD, use the one marked with the name of this Immersion Environment. For an add-on Immersion Environment, use that Immersion Environment?s CD. When the CD has had time to load, enter the correct drive letter for your CD drive, then click Retry the CD. [Note: All of the files for my Berlitz Italian appear to be on the same CD.]
    If you installed the multimedia for this Immersion Environment on your hard drive, click Browse and locate the multimedia files.
    When the red X marks change to green checkmarks, indicating that the files were found, click Open the Immersion Environment. [Note: The red X marks do not change to green, and the messages say Searching for the Sound Files, and There are No Video Files.]
  • jwisenthal Feb 10, 2009
    Reply to Benimur:
    Numer of CD drives: 1
    Virtual CD: No
    Hard drive partitioned: There are two hard disk drives
    Could the CD drive read the contents of the Berlitz CD: Yes
    Re-install program: I have had the same antivirus protection for some time, including the period during which the Berlitz worked.
  • jwisenthal Feb 16, 2009
    Message for rockitman187:
    I have copied the files as you suggested, and have had the following error message: "Error copying File or Folder. Cannot copy IE0693D. Data error (cyclic redundancy check)." Since IE0693D is precisely the file that cannot be found when I try to run the Berlitz Immersion Environment, we seem to be getting somewhere, and I'd be most grateful if you have any suggestions about how I could proceed now. Thanks.
  • jwisenthal Feb 17, 2009
    Memo to benwabnick:
    I couldn't seem to put back the computer to a date before December 30th, 2008, which I'm pretty sure was after the problem had begun.
    Cleaning the CD has made a difference, in that rockitman187's copying test worked -- ie without any error message. I then reinstalled the Berlitz, and I am no longer getting the old "CD Drive for IEO683D" error message when I click on Immersion Environment. But instead of the Immersion Environment itself, I am getting this mewssage:
    BLS application has encountered a problem and needs to close. Name: bls.exe AppVer: 1.10.0.14 ModName: quicktime.qts
    ModVer: 7.55.90.70 Offset: 000a30f4
    This, I think is the message I was getting a couple of months ago, which caused me to try reinstalling the Berlitz program in the first place.
    I have, by the way, tried rockitman187's suggestion about the registry, but the Value Data field was already set to "0".
    It looks to me as if we are now close to a real solution, and I look forward to suggestions from the extremely helpful people who have been kindly providing advice to me.
    I have updated the directX software, but the problem persists.
  • jwisenthal Feb 18, 2009
    I will try melnavz's suggestions as a last resort, but first I'd like to see whether the new error message I'm getting ("BLS application has encountered a problem and needs to close. Name: bls.exe AppVer: 1.10.0.14 ModName: quicktime.qts
    ModVer: 7.55.90.70 Offset: 000a30f4") might lead to some less drastic solution. Could "quicktime" be a clue?
    By the way, is a Uniblue Registry cleanup a good idea at $29.95?
    It turns out there were two problems: a dirty disk and Quick Time. Now both are solved.
    Thank you so much to everyone who helped me get my Berlitz Italian working properly again -- and especially to blueextc3221 and rockitman187. I am most grateful for all the assistance I've had, and I'd certainly recommend FixYa to anyone I ever encounter who has a software problem.
    Jonathan Wisenthal, Vancouver, BC, Canada
  • 15,935 Answers
Your Quicktime is crashing... Unfortunately, removing and re-installing will not help. You will need to remove Quicktime using Add/Remove programs..... then
CLICK HERE to be redirected to an installation page of Quicktime Alternative software.
Often times, this error occurs after the installation of iTunes software as they share manipulated files that are then not understood by other apps (BLS).
Thanks for using FixYa - a FixYa rating is appreciated.
Posted on Feb 17, 2009
  • 544 Answers
Thank you for using Fixyacom..
we have encountered as the same problem with berlitz..
The Berlitz was overall an average learning language software. The pack contained two computer programs for Mac and PC users (Before You Know It Flash Card program and Berlitz Language Learning System), a version for Palm Pilot, and four audio CDs.
The main computer program, the Berlitz Italian Language Learning System, seemed to be outdated and was not very easy to operate. I found myself confused in how to start lessons or which section of the program to even be in. The other program, Before You Know It Flash Cards, appeared to be more up-to-date and effective, with its only redeeming quality being an electronic flash card display with pronunciation.
The four audio CD's that came with the program, basically Berlitz's Italian Guaranteed audio program, were not very sufficient either and taught in a very fast manner. The audio conversations left very little time to respond or repeat newly learned phrases in each lesson. I was surprised at the average quality of these discs due to my previous great experience with Berlitz's Japanese Guaranteed, that was very helpful and taught at a slower pace.
Overall if you want to learn Italian quickly and effectively, do not buy this product. Safe up your money and buy Rosetta Stone Italian Version 3 and learn through their amazingly effective Dynamic Immersion Process. Seriously, when it comes to learning a language, Go Rosetta Stone
  • Mark Milan silaran
    Mark Milan silaran Feb 17, 2009
    thank you for using Fixyacom..
    Genius:
  • 1,226 Answers
Is the CD installed correctly? If yes then maybe you need a cd inserted in your CD rom every time you use the program.
However if you don't mind is the computer same with the computer you have been using before? If yes then i your system preventing you to install all the necessary files needed to open the the program.
first please copy your original CD/DVD to preserve the original installer. This might be damage when you always use the CD/DVD every time you install the program.
did you try installing this program to another newly or clean computer other than your current computer. if not i advice you to try installing in other computer such as in your friend comp.( anyway you uninstall that later.)
If this work in other computer then probably you have to renew your computer system by formatting and re installation of new OS. (You can search in google the procedure in windows installation)
tell me if you try already and what is the result.
may this initial help,
melnavz
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Pls try upgrading ur directX software
  • Rodolfo Atun Feb 17, 2009
    sir,
    try to adjust ur computer to the requirements of the software... that could help the problem... if no luck, better visit the after sales support of the program on the net.
  • 360 Answers
I have read your posts and the solutions given. It appears to me that the problem is either a dirty/damaged disc, or a partially inoperative drive. This is what I would do.
  1. Thoroughly clean the CD drive (use a cleaning disc of good quality) note: if the cleaning disk has been stored in a standard CD case, the brushes are probably flattened and will not work properly.
  2. Thoroughly clean the CD. I actually use warm running water and Dawn dish washing liquid and a soft lint free cloth to dry the CD. I wet the disk, drop a little Dawn of the disk. and using my fingers and a light touch, wash the disc, then rinse under running warm water, then dry the disc with the soft lint free cloth, dry the disc from the center out, do not use a circular motion (I use a lens cloth).
  3. Now with the CD completely clean, inspect it for any damage, ie; scuffs or scratches. If damage is apparent and the final step 4 does not work, the disc may need replaced.
  4. With the now clean CD drive and the clean CD, reinstall the program.
Let me know what happens please.
Thanks for using Fix Ya,
clarkco
Posted on Feb 16, 2009
  • clarkco2002 Feb 17, 2009
    Uninstall Quick time, reboot the computer and attempt to use the
    clarkco
  • 217 Answers
  • 1 more comment
  • Saroj Sharma
    Saroj Sharma Feb 16, 2009
    The cyclic redundancy check or "CRC" error indicates a bad spot on your storage media. The fact that you're seeing it when you try to copy a file indicates
    that the bad spot may be within the file itself.So seems the CD has got a bad spot and for that reason system is not able to copy the required file.
  • Saroj Sharma
    for more information on cyclic redundancy please click here
  • Saroj Sharma
    Saroj Sharma Feb 18, 2009
    Instead of uniblue Registry booster try Regseeker its free and much better than uniblue I have used both I find regseeker much promising. above all it does not need installation it's a stand alone software.
    download it from here
  • 2,404 Answers
I have a strange idea, it could be a problem with the registry. May have corrupt information about the program in there. Try to do a system restore back to the last date when the program was working.
To get there click on "start", "accessories", "system tools" and then click where it says "system restore".
This program will allow you to put your computer back to a date of your choosing. The ones that are highlighted are the dates you can choose from. I suggest you go back to a date when the program last worked. Then what will happen is your operating system will revert back to the way it was on that date and it will reboot your computer.
After this if the program is still installed, try to run it, if its not installed then run the installation and try it after its installed.
If it doesn't work after this then try the program on another computer and if it works then you know its a problem with Windows XP on your computer. That would mean you have corrupt system files on the hard drive.
Posted on Feb 10, 2009
  • 350 Answers
Dear jwisenthal,
There are many drivers on every computer and if they are not up to date things won't work properly so...
Driver Update Software Recommended: @
http://www.driversupdate.org/?gclid=CKjWiPnXyZgCFQECGgodC1QR0g
I'd go to the above site and click on DOWNLOAD NOW. This will install a prized program to periodically update all your drivers. The program will appear on your desktop as ParetoLogic DriverCure.
Run it often to keep all your drivers up to date!
This will take some time and effort but is worth it!
If this doesn't work please get back to me and let me know!
jack
Posted on Feb 09, 2009
  • Jack Iaria
    Jack Iaria Feb 09, 2009
    My last posting on Feb 9. 2009 was at approx. 3:39PM EST (USA) this one is 3:43PM EST (USA)
    jackiaria
  • Jack Iaria
    Jack Iaria Feb 16, 2009
    Dear jwisenthal, 2-16-2009 2:59pm EST (USA)
    RE: Nova Development Berlitz Italian Premier Full Version for PC, MAC
    Berlitz Can Not Find Multimedia Files for Immersion Environment
    I can understand your frustration in trying to open files that were opening but now are not!
    I can not emphasize enough the importance of DOING FREQUENT UPDATES of both the OPERATING SYSTEM, like WINDOWS XP, and UPDATES of ALL YOUR COMPUTER DRIVERS and SOFTWARE. Most Computers have dozens of these and unless you UPDATE OFTEN sooner or later one or more will STOP WORKING! This is what is happening in your situation since your program worked then just stopped for no reason.
    Since so many viruses are being released so often many files that once opened will not open now because they do not have the updated software to scan for them and rather than risk opening the file they choose to not open it and give you an error message.
    Do you understand this?
    Going to each manufacturers site and getting the latest updates frequently is time consuming and unproductive so I'm begging you to go to http://www.driversupdate.org/?gclid=CKjW... (just click on the preceding http:// link) and DOWNLOAD "ParentoLogic DriverCure" !
    It's not necessary to buy the premium program just download the free one!
    As I said in my previous solution ParentolLogicDriverCure will appear on your desktop. RUN it NOW and Run it Often!
    I am confident this will fix your problem and help keep your computer running free from other similar problems in the future!
    If you have any problems installing it let me know!
    One more thing! Have you been getting UPDATES for your WINDOWS XP? If not do that 1st @ http://www.update.microsoft.com/windowsu...
    jack
    Genius:
  • 1,011 Answers
Sir,
This link shows 'how to install the program' check out. it applies your software and also update the Operating System. it may be solved.
Link 2
thanks good luck
    President:
  • 2,559 Answers
  1. Insert the disc in the drive. On the Install screen, click the Exit option.
  2. Open the My Computer option, which may be found on the desktop, or on the Start menu.
  3. Right-click the drive that has the disc in it.
  4. Select the Open option from the pop-up menu.
  5. Go to the Edit menu and select the Select All option. All the files and folders should now be highlighted.
  6. Go to the Edit menu and select the Copy To Folder option.
  7. On the Copy Items window, scroll to the top of the list and click the Desktop option.
  8. Click the Make New Folder button.
  9. You should now see a folder labeled “New Folder” with the text highlighted. Change this to something like “Copy Test” and click the Copy button.
This will copy all the files from the disc to your computer’s hard drive. If you get an error message while it is trying to copy the files, it is likely that there is a problem with the disc itself.
If all the files copy with no problem, then there may be an issue with one of the settings in your registry. Please try the following:
  1. Click the Start button and go to the Run option.
  2. In the Run window, type “regedit” without the quotes on the Open field and click the OK button. This will open the Registry Editor.
  3. Scroll to the top of the left-hand side of the window to where you can see the My Computer option.
  4. Locate the HKEY_LOCAL_MACHINE folder. If it has a plus (+) sign next to it, click the plus sign. If it has a minus sign next to it, skip to the next step.
  5. Click on the plus (+) sign next to the SOFTWARE folder and this will expand a list below it. If it has a minus (-) sign next to it, skip to the next step.
  6. Click on the plus (+) sign next to the Microsoft folder and this will expand a list below it. If it has a minus (-) sign next to it, skip to the next step.
  7. Click on the plus (+) sign next to the Windows NT folder and this will expand a list below it. If it has a minus (-) sign next to it, skip to the next step.
  8. Click on the plus (+) sign next to the Current Version folder and this will expand a list below it. If it has a minus (-) sign next to it, skip to the next step.
  9. On the list that appears below Current Version, locate the Win logon folder. Click once on the Win logon folder name.
  10. On the right-side of the window, double-click on the "allocatecdroms" name.
  11. Change the Value Data field to "0" without the quotes, if it is set to anything else.
  12. Close all windows.
  13. Restart your computer.
Now you can open the folder and install from there,or insert the disk and reinstall.
Please let me know if you need any more help.
Posted on Feb 08, 2009
  • Randy Hough
    Randy Hough Feb 10, 2009
    1. Identify the file that cannot be opened.To identify the file, follow these steps:
    2. Click Start, click Run, type EVENTVWR, and then click OK.
    3. In Event Viewer, click Application log.
    4. Click the Source column heading to sort the list by source and to list all the Application Error sources at the top of the list.
    5. Search for an event with a source of Application Error and an event ID of 1005.
    6. Double-click this event.
    7. The file that cannot be opened will be listed in the Description box. Note the file name, and then close Event Properties.(or post the log on here)
    8. Try to open the file again. The problem may have been temporary and may not occur when the program runs again.
  • 6,784 Answers
Ok, this is what happens to files if your hard drive becomes fragmented. heres an easy fix. You will need to defragment your hard drive. this may take a few minutes but, its well worth the wait. once it is complete, restart your pc and your files will be able to be located once more. hope that helps and , thx for using fixya:)
  • Michael Masters
    Michael Masters Feb 08, 2009
    Another neat tool that is very good for keeping your system healthy is a registry cleaner. this is very important for system health that your registry is clean of all clutter at all times if you use your pc often.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas you may want to explore/consider:
  • how many CD drives installed?
  • is a virtual CD installed in the XP computer?
  • is the XP computer's hard drive partitioned to more than 1?
  • could the CD drive access/read the contents of the CD. To verify, double click on My Computer, right click on the CD drive, click Open;
  • re-install the software with the antivirus/firewall temporarily disabled.
Pls post back updates on any developments.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 10, 2009
    My suggestion to disable the antivirus is only during the re-installation process.
    President:
  • 1,214 Answers
It would be good to know what other processes and applications are running after you do a fresh reboot, without starting anything else. Reboot, press Ctrl|Alt|Del, and press the Task Manager tab.
Read the number of programs running by selecting appropriate tabs and looking at the bottom of the window.
Also, how much memory does your computer have, how big is the hard drive, and how full is the hard drive?
Posted on Feb 02, 2009
  • Mark Egan Feb 10, 2009
    If you have more than 1 CD for the Berlitz system, have you tried each CD in the drive and allowed the Berlitz system to search again?
    When you installed or reinstalled the Berlitz system, did you save the installation to the hard drive as instructed?
    After you have rebooted, have you gone to Device Manager to see that the CD player shows up, and there are no exclamation marks or red x's next to it?
  • 11,896 Answers
Http://www.transitionsabroad.com/listings/study/language/language_study_and_immersion_resources.shtml
copy and past this link into your address bar. It has many facts and information about your program
  • 19,396 Answers
You will probably have to set the default multimedia folder, or to start a new installation of Berlitz software using a different folder.
Insert the exact error message you are getting in the support page here.
  • Ginko
    Ginko Feb 08, 2009
    When you do Berlitz setup the Install Wizard will ask yo if to do a Standard Installation or Custom Installation.
    Chose Custom installation.
    On next step you will be asked to chose install folder, modify install folder changing the last folder to berlitz01 or something similar.
    Installing the software on a different folder should fix the problem.
  • 565 Answers
  • 679 Answers
Download directx and then install it.
download from>>
http://www.softwarepatch.com/windows/directx.html
Thanks for using FixYa.
  • rockfixya
    rockfixya Feb 08, 2009
    You need to upgrade the RAM memory.
    Expand the RAM memory of your system,
    that will help you.
    Thanks
    Sergeant:
  • 326 Answers
Software problem.as its turned faulty.just check out in any other system to confirm the fault.
    Brigadier General:
  • 8,619 Answers
Hi!
Try downloading the flash player from the link and after installing them i believe you would be able to run that again. This software helps to run multimedia files on your system.
Flash Player
Posted on Feb 01, 2009
    Brigadier General:
  • 5,158 Answers
Do you have that problem with other programs. it sounds like it wants to have the cd in the drive when you run the program
Berlitz english premier nova development
Purchase the software and you can get the licence key.
May 29, 2012 | Computers & Internet
Nova Development Berlitz English
Purchase the software to get a licence key. If you have already purchased the software contact Nova support to have them issue you a new key.
I tried to load Print Shop Premier 5.0 into a new computer running Windows 7. I got an error message that said Print Shop Premier 5.0 would not run on the 64 bit operating system. Is there an upgrade or...
The following are some options:
  • Try running the program in 'Compatibilty' mode: this option can be found via the context menu 'properties'.
  • Install a 32 bit version of windows in a Virtual Machine and re-install this application: you can download the free VPC (Virtual PC) from Microsoft web site or VirtualBox from www.virtualbox.org (this is what I use on my W7 Ultimate 64 bits laptop as it has good USB device support).
Hope it helps and good luck.
Dec 17, 2010 | The Learning Company The Print Shop...
I need to practice on Quickbooks Premier 2008 for students ( or something like that) Where can I found this program whit backup files?
The best program for learning QuickBooks is the free Simple Start Version. You can download it for free at quickbooks.com.
www.cpahispano.com
Mar 27, 2010 | Intuit QuickBooks Premier 2008 (3-User...
I have downloaded the French Berlitz software and everything works fine. Including Imersion environments. When I installed the Chinese/ Japanese Premier software, I could not see Chinese or Japanese...
i have never hear of that software, If you have any difficulties in search, download or convert video/audio,
You may try this powerful and easy-to-use video/audio converter.
Video Sharer can help you convert video/audio, my friends recommend it to me, and it’s easy to use and works pretty well for me.
With it you can:
1: search videos and free music from popular online social media websites like YouTube, Dailymotion, and many others.
2: download music and videos that your are searching for
3: convert these videos/ audios to any format as you like.
you can find it here: http://www.asharer.com
Jan 27, 2010 | Novatel Berlitz Chinese & Japanese Premier...
Can I retrieve files
You can. Just to be safe, backup the printmaster files and then proceed with the new printmaster disk.
May 31, 2009 | Mindscape PrintMaster Premier 7.0
Novatel Nova Development Berlitz Italian Premier Full Version for PC, Mac  Logo
645 people viewed this question
Top Novatel Computers & Internet Experts
ray gallant
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
