Question about Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have a Samsung LN-T4071F. When I power it on, the picture is strong and clear. After 10-15 minutes though, the picture begins to get grainy, and gets continually granier as it stays on. What could be the source of this problem and is it worth fixing or should I invest in a new TV?
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Posted on Jul 08, 2013
3 Suggested Answers
lightnbaby
  • 36 Answers
SOURCE: Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Posted on Aug 05, 2009
james tv man
  • 88 Answers
SOURCE: My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Posted on Jun 07, 2010
Picture jumps
Sounds like a fault with the connection to its T'Con board to display panel. Check for any loose contact at the both ends of connection sockets to LVDS cable. (Low Voltage Differential Signaling) {that involves transferring a signal on a wire and its opposite over a second wire to allow the receiver to reconstruct the signal by difference}. Re-seat all the cables that comes to and goes from the T'Con board once, and check. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
Jan 24, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
Power cycling
a0b65409-5b20-4df7-a509-196d94a9ef02.jpgI haven't worked on that exact model but your symptom is similar
to others of that series. The filter capacitors tend to age and bulge up on the top. They are fairly cheap so consider changing all of them in that area.
Nov 13, 2013 | Samsung LN-T4071F 40 in. LCD HDTV
I was moving my samsung 40 ln-t4071f and cracked the screen. Can i buy one somewhere and could i replace it myself?
To replace the screen is going to cost about at least $500.00.
I will try to sell the tv as is for parts. You can probably get about $100.00 . Thats how much I buy them for.
May 09, 2010 | Samsung LN-T4071F 40 in. LCD HDTV
It would be too costly to fix! I recommend giving the set to your local waste management program.
Mar 17, 2010 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH LINES GOING THRU SCREEN AND PICTURE FLICKERS
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
Dec 30, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Television display
This normally causes by failure of power supply board. Some time it causes by failure of inverter board, in this case you can see the picture moving on the dark screen as it has no back light.
Aug 18, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
We have a Samsun LN-T4071F LCD TV. The screen is all white and colored vertical lines. We disconnect the HDMI cable from the Dish box and the screen stays that way. We turn the TV off for a couple hours...
Do you have warranty on this unit?If warranty available contact servicer.
From your description problem is in the Digital board.
Replace digital baord.
Dont forget to Rate!
Good Luck
Dals123
Oct 22, 2008 | Samsung Televison & Video
Grainy
Unless you are watching an actual hd station this is how it is going to stay for you. Sorry your real quality comes in when you are actually being fed a true 1080 I signal not some upgraded 480.
Thanks
Josh
Jan 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
