Question about Americana Range. 30 in. Freestanding Electric Range in White ABS200PWW
How to install oven element
The oven element burned out and broke in 3 p0cs. how do i replace it?
    Top Expert:
  • Americana Master
  • 9,472 Answers
Here is the element to order. There is also a repair video on the same page to show you how to make the repair.
Posted on Jan 21, 2013
Will just replacing the oven element fix my Kenmore model 911.955879range oven? It sparked, broke in two and a white flame continued going around the element, wouldn't stop I had to shut breaker off.
Hello Jennifer;
My name is peter. I am a retired field service appliance technician.
Good for you - turning off the breaker.
You have a older oven. Usually there is a spark or crack in the oven element. In your case the element was so embrittled it broke into 2 pieces.
Before you use the top range burners to be on the safe side you need to disconnect the oven element. You may have damaged the oven control board to where it is locked into power for the oven.
25713262-01ium3bsyoj5ql4fhv4kpwvp-4-0.jpg 1.) Remove the bottom drawer to reduce weight.
2.) Put a rug on the floor in front of the oven, so when you pull the oven out it does not scratch the floor.
3.) Pull the oven out so you can get behind it.
4.) Unplug the unit.
5.) Remove the back bottom cover.
6.) Disconnect the heating element and remove from oven.
7.) Rap the two loose element connections in the back with electrical tape.
8.) Follow the element loose connection to the control board at the top. Disconnect at the oven control board.
9.) Inspect the loose wiring from the control board to the heating element for burns or melting.
10.) Plug the oven back in and turn on the range burners.
The part number for the oven element is WB44T10014. Sears wants about $95.00 for this part. Search the internet for this part number and get it for about $28.00.
Your oven control board may have become damaged. Recently I replace one for a friend. Sears wanted $256.00. I got a remanufactured board over the internet for $30.00.
Get back to me and let me know what is going on.
May 25, 2015 | Kitchen Ranges
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
The lower oven element actually broke in two. Is
this is common u need a replaceemnt they vary anywhere from 30-80 dollars, grease buildup and use can cause those to burn out and break..
Feb 15, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Neff 1721 0ven element not working??
did you replace both fuses, if its a 240 volt element check the other fuse on the other leg of input power/120 volts + 120 volts = 240 volts
Oct 05, 2009 | Neff U1721 Double circotherm Electric Oven
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Oven burner
hi thanks for the question. you saw the element burn its self out . its burnt out know don't worry go to bed . replace the element tomorrow . thanks the appliance doc
Jul 03, 2008 | GE Profile JTP18 Electric Single Oven
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Need help replacing the Broil Element in our Whirlpool Dbl Oven GBD307
It is easy to replace.   Turn power off to the oven.    Remove the screws holding the element to the inside of the oven, Carefully pull the element out of the oven liner until you can unplug the wires from the element. Hook up your new element and ease it into place and re-install screws.
You can get the part from any whirpool servicer or you can order it from Sears.
Oct 13, 2007 | Whirlpool GBD307PDS Electric Double Oven
Americana Range. 30 in. Freestanding Electric Range in White ABS200PWW Logo
60 people viewed this question
Top Americana Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you an Americana Kitchen Range Expert? Answer questions, earn points and help others
