Question about Rockford Fosgate (P210D4) Car Subwoofer
15 in subs wont trun on
I got two rockford fosgate power dvc's an when you hook them up they dont trun on, i was woundering if anyone know where to send them in an get repaired
    Problem Solver:
  • 10 Answers
Hello. You can call Sound Repair 321-690-0808 for estimate.
Posted on Jan 28, 2009
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
Wireing 12inch dvc 4 ohm subs
well rockford has a simple site to wire up your subs shows you how to configure them go to rockford fosgate woofer wiring wizard. and itll show you what you want to know..
Jan 03, 2013 | Rockford Fosgate Car Audio & Video
Where can i gt wiring diagram for phenix gold 12 dvc sub
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
I recently hooked up a new kenwood deck put new front and back speakers in. I hooked up a 1200 watt hifonics amp about to plug in my 2 15 inch rockford fosgate speakers rfz1412 and they dont play. All the...
Ok, so I am assuming that the other speakers are working, and it's just the subs that are not, right? If this is the case, start from the source. Make sure the RCA cables are plugged in and not crimped anywhere. Then to the amp, Did you check the gain levels on your amp. That is the knob next to the RCA input on the amp. Also, check the wiring to the subs. Make sure all your + are goinig to +. Sometimes in the "heat" of a good install, you just lose track of those things. When in doubt. Undo all your wiring and start from scratch. Good luck.
Aug 30, 2011 | Rockford Fosgate RFZ1412 Car Speaker
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
I want to hook up my 2 quad coil woofers to a 1ohm amp but
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
Mar 22, 2009 | X-10 Memphis 15-PRC41 Power Reference 4" x...
Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Rockford Fosgate (P210D4) Car Subwoofer Logo
105 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
