Question about Swann Communications DVR4-Alert Video Recorder
I Need A Manul For A Swann DVR4-Alert SW242-ALR Free
4 Suggested Answers
raygin
  • 322 Answers
SOURCE: Motion recording for Swann dvr4
Have you switched cameras to AUTO (A) on settings line. Is the sensitivity for motion turned on and set correctly =
1= very sensitive 9 = less sensitive.
Setting areas are shaded = no recording area
unshaded = recording area
Hope this helps - good luck.
Posted on May 11, 2009
raygin
  • 322 Answers
SOURCE: Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Posted on Oct 28, 2009
walesarumi
  • 6993 Answers
SOURCE: regarding dvr4-net-plus, video output is
The graphic settings is the cause of this. The display on the monitor has to be on either NTSC or PAL depending on your area/location.
Also after starting the DVR, you must ensure that the DVR's input video (NTSC/PAL) and your TV/Monitor (NTSC/PAL) are both set to the same standard.
If they are not set to the same standard, that is, if the DVR is set to PAL and TV/monitor is set to NTSC, this can cause the video out put to have constant horizontal line.........
So make sure both video output are the same....
I hope you understand the above.
Good luck.
Posted on Mar 02, 2011
How do I reset password on swann DVR4-3450
You will have to call swann about this. I don't use passwords on my security system because of this.
Mar 07, 2015 | Swann Communications Televison & Video
Swann video recorder is flashing red light
My DVR box is powered up but, i get no picture and the HDD red light is flashinG
Feb 13, 2013 | Swann Communications DVR4-Alert Video...
Red and green lights blink but why is there nothing on screen?
The voltage from the power adapter is critical for proper operation. If it's a little low, the lights will work, but not the picture. There are capacitors on the motherboard that fail with age, so check them too.
Dec 08, 2011 | Swann Communications DVR4-Alert Video...
When i press record a message comes up saying no hdd to write
hi,
i think ur its storage device hdd have some problem. the hdd is not detecting. check the connections of hdd for any loose contact. if found faulty replace it.
ok
Dec 23, 2010 | Swann Communications DVR4-Alert Video...
Need software for Swann DVR4-1100 to work with Windows XP
Please visit the below website, ad then select the model number and the product to download the driver(software) of your DVR. The product should be on the box or on the original invoice of the DVR.
You can download the product code SW244-DUM or SW242-DU2.
Please check on the invoice so download the right one, or else can try both of these one by one.anand_sachan_0.jpg
http://www.swann.com.au/s/techcenter/download
Regards
Anand Sachan
Nov 05, 2010 | Swann Communications PC-DVR-4 NET...
PASSWORD FOR SWAN DVR ??
Hi
The unit has a default password = press CH1 (channel 1) button 6 x times
good luck
Jan 02, 2009 | Swann Communications DVR4-Alert Video...
Hdd set to master
my dvr4-alert does not record no hdd
Jul 23, 2008 | Computers & Internet
Mar 14, 2008 | Swann Communications DVR4-Alert Video...
Swann Communications DVR4-Alert  Video Recorder Logo
74 people viewed this question
Top Swann Communications Televison & Video Experts
Electro Med Services...
Jerry Kramer
Jerry Kramer
Jack Frost
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
