Question about Haier XQB60-91BF 1.92 cu.ft. Portable Washer
Spin dry I have a Haier washing machine model XQB60-91BF. The machine still functions and washes but when spinning to dry, the machine will stop and will not spin dry. I was told it is possibly the the two motor under neath the washing machine. I am only able to identity one motor which is the drainage motor. What part must I need to replace? Thank you
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Posted on Feb 12, 2014
SOURCE: my haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
Posted on Aug 28, 2008
SOURCE: Haier XQG50-11
I had this same problem. There are two possible solutions. First, you need to look underneath (use 2 people) and see if any hoses are kinked. If that is not the case then the machine is pulling in too much water during the dry cycle. I'm hooked up to a sink so I just turn the faucet down until the water is just a trickle. This works for me. If yours is attached to the wall you need to turn down the cold water tap. Its a pain in the ****, but I discovered no one can fix this machine, not even Haier's recommended service A&E. I always know more than the repairmen, very sad. Hope this helped you.
Posted on Nov 21, 2008
  • 100 Answers
SOURCE: dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
Haier washer model xqbm22-c, fills with water and won't wash or spin, just hums through cycle and will drain. What are possible problems?
bad water pressure switch, bad door switch? bad motor coupler and or belt. the water pressure switch does not control the spin though? so I suspect door switch or coupler
Mar 07, 2015 | Haier Washing Machines
Does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Haier XQBM22-C Top Load Washer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Machine not spinning out comes up error7 it is a haier hns 1460 tve model , pump is filling up and emptying drum ok , took back cover off belt and spider both fine drum turns if you turn belt what could be...
Check lid switch.
If you have wash action from then the motor is most likely O.K.
If your lid switch is faulty, the machine stops before the spin cycle.
Ash
Oct 21, 2009 | Haier Washing Machines
Will not spin dry clothes.
My washing machine doesn't work, alarm on spin function
Mar 13, 2009 | Frigidaire Washing Machines
My haier washing machine doesnt work properly
Jul 30, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Mar 07, 2008 | Washing Machines
Haier XQB60-91BF 1.92 cu.ft. Portable Washer Logo
153 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
