Question about Kohler Home
Replacing the tower flush seal on a Kohler K4632 AA
4 Suggested Answers
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
  • 81 Answers
SOURCE: I have a K4632-AA which usually works just fine
Toilets seem to run on their own because the water in the tank is seeping our past the seal that was designed to keep it in the tank inbetween flushes. Commonly called flappers, they go by seals, tank balls discs. etc. The K4632 requires a flat seal from Kohler. The actual part number is 1059291, however Kohler may only sell this as part of a kit by a different number with pieces not truely needed in your circumstance.
You should contact them at 1-800-4KOHLER, navigate the prompts, and talk to a service member. You may have to do some research in your area to find a retail or wholesale business that will order this for you. There are circumstances where, with some parts, Kohler will send the parts free to your doorstep. No promises on this one. I have put a link below that will give you a complete parts explosion for your reference.
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=28e40a91273141a5b63e28ad7230d6a5&ModelID=e9143848792b4415a62b4e384caeb856
Posted on Nov 09, 2010
  • 7 Answers
SOURCE: I have a Kohler elongated toilet that is about 4 years old. It occasionally makes a flushing sound on its own while not being used. A plumber said I needed to replace the Comarron tower flush valve,
You can look at the gasket thats hooked between the flush valve and the toilet and see if its in bad shape and letting water get past it and eventully flushing your toilet. If its bad i would try to find one similar or drain the holding tank and use a little clear water proof silicone on it. Use a paper clip to clean out the hose going to the flush valve and you should be good to go.
Posted on Sep 03, 2012
My Kohler K4493-AA occasionally produces a high-pitched whine like a smoke alarm. Flushing stops it, but then the sound comes back later. Any ideas?
Typically it's one of two things. Either there is debris (Sand, gravel or hard water deposits) under the seal diaphragm inside the fill valve or the diaphragm has deteriorated. Shut off the water to the tank, take the cap off of the fill valve and remove the diaphragm. If the diaphragm has deteriorated, replace it Kohler #83143. Otherwise, rinse it off, turn the water on just a bit to let it bubble over the top of the fill valve and rinse out any debris. Then with the water trickling, put the diaphragm back in and replace the top assembly. When all is secure, turn the water back on to full.
Sep 26, 2015 | Kohler Home
Kohler 84296aa
This part is available at Home Depot hardware stores.
Oct 09, 2017 | Home
I have a Kohler elongated toilet that is about 4 years old. It occasionally makes a flushing sound on its own while not being used. A plumber said I needed to replace the Comarron tower flush valve, a...
Sep 03, 2012 | Kohler Cimarron 2-PC Elongated Toilet with...
My Kohler toilet K-4632-AA keeps running how do I fix it?
Plumbers Brisbane West : For any Plumbing Emergency please call us anytime - 0411 179 978. Your Local Plumber in Brisbane's West - On-Time - Everytime.
Mar 05, 2012 | Kohler Cimarron Comfort Height elongated...
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
I have a K4632-AA which usually works just fine but now it has started to run water every few minutes. What might be the probelm and how can I fix it?
Nov 09, 2010 | Kohler Home
We have a 1.6 gallon single unit Kohler toilet that just started leaking at the top of the flushing mechanism (inside the tank). The toilet serial number is K3386DA - 20190. The flushing mechanism is...
http://www.lockeplumbing.com/detail.asp?c=Toilet%20Parts&s=Kohler&s2=Float%20/%20Fill%20Valve&sku=KOH-1068030&r1=WHE-USS25C&r2=&r3=
See if your filler valve looks like the one in the picture from the link above.
Aug 21, 2010 | Kohler Home
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Home Logo
95 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
