Question about Summer Infant Secure Sight Handheld Color Video Monitor 02040
No sound The video on the monitor works and so does the light indicating the sound level but the volume up button no longer works. The sound is stuck in the off/low position. It was purchased prior to April 2011
2 Suggested Answers
SOURCE: My Summer Infant slim &
I had the same thing happen! I didn't have a solution when I first read your post but I got mine to work again. When I took the battery out of the hand held unit (the parent one) and put it back in it stared to work again. By that time the battery had gone dead because it had been on for a day while I struggled to find a solution (it stopped working in the middle of the night). I am going to email the company as well. Maybe there is a defect in the product? I know the ones sold a few months ago were recalled because the battery was overheating and causing the monitor to work. For now mine works but I figure notifying the company may help because if others are having this same problem there might be a defect and they can recall the product or at least replace it when it happens to us again.
Posted on Jul 14, 2011
Monitor will cycle through the menu screen every few seconds after being turned on.
the menu button is stuck,use a sharp knife to pry the button out very lightly,not all the way out,just enough to make sure that it isnt stuck,if it still happens then the board for the menu button needs to be replaced
May 27, 2015 | HP w1907 LCD Monitor
My TD-26 turns on and it has high level volume. It"s don"t like me. How change it when is it turns on and has medium level volume
the volume has the issue, I suggest you try to clean it up with the right liquid, or try to see if it is stuck!
Jun 04, 2014 | Santai TD-V26 Portable Mini Digital...
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Sound indicator
you can find it in control panel option.do this-
  1. click on start button on task bar
  2. click on settings option
  3. click on control panel option
  4. in control panel click on (sounds and audio devices) option.
  5. and click on place volume icon in the task bar.thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 24, 2008 | HP Vs17 17" LCD Flat Panel Monitor
My psp sound quit working. it went low and now no sound at all.
I take it the volume control doesn’t change it? If the level went down rather fast the Volume decrease button (-) might have gotten stuck down.
Have you tried different set of ear buds (headphones)?
Mar 21, 2008 | Sony PlayStation Portable (PSP) Console
No sound from the monitor
Plug the monitor speakers into a source of constant sound (mp3/cd player) and make sure the monitor is not muted and volume is at least half way.
If that works adjust the volume and mute settings on the computer
Mar 08, 2008 | Liquid Video E15LCD1 15"
Summer Infant Secure Sight Handheld Color Video Monitor 02040 Logo
29 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
