Question about Husky Husqvarna Chain Saw 240E w 16in bar
I have a 240 husqvarna saw have used 3 tanks of gas now it wont prime
It wont prime and it is a new saw used about 4 times
  • Husky Master
  • 2,239 Answers
The primer pulls fuel from the metering side of the carb, if there is no fuel here it is because either the fuel filter in the tank is blocked, or the fuel hose is trapped, or the non return valve in the carb itself is stuck, this can happen if the saw has been left with a rich oil mixture left in it.
Posted on Jan 21, 2013
Huaqvarna chainsaw 240 runs then quits
when ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Nov 27, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 236 brand new will not start
1. Make sure you have used the correct fuel to oil mix in the tank.
2. Set on/off switch to ON position.
3. Pull out the choke switch to (full choke position)
4. Prime the carb by pumping the primer bulb on the carb until fuel fills the bulb.
5. Pull over saw until the saw fires.
6. Push in the choke switch.
7. Pull over and the saw should start.
May 09, 2013 | Husqvarna Garden
Husqvarna 240 want start at all
Sounds like the ignition module or spark plug. The ignition module is what controls the spark plug that gives your saw the firing capabilities. Before you purchase one of those, replace the spark plug and see if that works. The 240 is a newer husqvarna; so I am skeptical to say it is the ignition module. However, any new product can have a bad part on it.
Your saw may have gotten flooded and won't start. Make sure your gas mixture is 50/50 gas to mixing oil. Always use fresh gas. If you make up gas and don't use a whole gallon at a time, put some fuel stabilizer in the mixture; so it will still be fresh the next time you use it.
Oct 28, 2010 | Husqvarna Chain Saw 18" 450 Model...
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Chainsaw ran out of gas. Filled tank will not start now. Husqvarna 450 e=series 18"
Those saws are very finicky. First shake the saw very vigorously, as the saw running dry mayy have sucked dirt to the intake screen. Clean the plug and check gap. Prime, choke and pull till it starts. your plug may be foulled, this happens alot when a saw leans out from running out of fuel.
Jul 22, 2010 | Husqvarna 450 e-series 18" Chain Saw
New 445 husqvarna chainsaw will not start
Drain the fuel tank, look inside the tank to ensure that the fuel line inside still has a fuel filter attached to it.
Look at the on/off switch ensure that both the wires are still attached to the switch securely.
Check that the plug still has spark, if unsure replace the plug.
Check the air filter to ensure that it is clean.
Mix the gas 50:1.
Sep 17, 2009 | Husqvarna Garden
Saw runs good when you prime it cant get it to get gas from tank
Sounds like you have a plug between the tank and the carb. I would change the hose between the two and clean the tank as well as the carb.
Jul 27, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain saw wont start after running out of gas?
Hi
Fill the gas tank with new fuel.Priming the engine(put some gas in the sparkplug hole for few times and start the engine until it runs constantly):There is small amount of water in the gas.
best regards savumihai71
Dec 27, 2008 | Poulan Pro Chain Saw 46cc 20"
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husky Husqvarna Chain Saw 240E w 16in bar Logo
139 people viewed this question
Top Husky Garden Experts
David Patricia James
Level 1 Expert
bryant
Level 1 Expert
Are you a Husky Garden Expert? Answer questions, earn points and help others
