Question about Tascam 2488 Portastudio Multitrack Recorder System
My Tascam 2488 Freezes during recording
This freeze has been happening now periodically for the past couple of weeks however only during this new track I am in the process of finishing. My tascam freezes mainly in the middle of my vocal recording. But it does freeze as well from time to time when just playing back a track. I am recording this vocal on channel 1. A split second just before freezing, the volume, on its own, triples in loudness and stay at that level until it unfreezes. This, perhaps needles-to-say is beginning to give me a conditioned fear of anticipation in all honesty. But regardless of that, the system freezes for either one or two minutes. While it freezes, all the lights on the board go out except the green LED screen and the small red lights on channels 2, 3 & 4(only those channels) that let you know when the instrument the channel is using is too loud. And then after about a minute or so, sometimes just a few seconds, sometimes longer, everything comes back on again and it's back to recording. But then it does it again. Then sometimes after the third time or so, it stays frozen for quite some time, maybe a few hours before returning back to normal again. Sometimes actually all I need to do is gently slap the side of the unit and presto it's back again. I have tried rebooting the system when this happens. When I do, the system reboots straight back to the track I was on without in fact going into "Mixer Check"(which I know from experience can take hours to finish when booting down improperly). But the reboot never fixes the issue. Can anyone help me with this problem? I feel like my system is simply unstable and failing. Is there something I can do to fix it? I'm struggling just to finish this track. Many thanks for your help.
Greg
  • 1,031 Answers
This may be a problem with the Hard Drive not getting enough power to spin up properly so it will cause the system to freezee upm regularly check the AC power adapter if possible replace also you can . download the software update 1.01 from tascam.com, that will improve the performance.hope this helps
Posted on Jan 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Have you ever tried to reformat the HD? It can get fragmented over time that slows down HD access, and may not be able to keep up with a steady stream of data being recorded and thus hangs in middle.
Drives could also develop bad spots on the disk surface. Use your recorder's format utility that does a surface scan which usually deallocates any bad sectors from future use.
Also back up the important stuff and reformat the drive first before spending big bucks on a new recorder.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    If you still have a problem, take your drive out of the recorder, install it in your PC and reformat there.
    You can also check for bad sectors using chkdsk from a command prompt. The command would look something like this "chkdsk /F D:" The /F switch would fix errors on the disk.
    Put your drive back in your recorder, reinitialize it again and try recording again.
  • 716 Answers
Hey Greg My Names Mike You Need To Get Everything Off The Machine Save It Now. I Back Up All My Data To Disk For This Exact Reason. You Need To Get It All Off And Reformat The Hardrive Depending On What your Machine Calls It Some Call It Initialize.
But Make Sure You Get All Your Data Backed On Disk Because Doing The Initialize Will Delete Everything And Close Bad Sectors Of The Hard Drive off. Hopefully You Don't Need A New Hard Drive. Most Likely Not, Once You Have Gone Through The Whole Process Put All Your Data Back On And It Shouldnt Freeze Anymore.
I Hope This Helps And If You Have Any Questions What So Ever Let Me Know.
Sincerely,
Michael Scott
  • Michael Fisher
    Michael Fisher Jan 26, 2009
    If You Don't Have Your Manual You Can Download It Here. Click Here
    Under The Resources Tab It Has A Download Of The Updated Manual And A Bunch Of Other Really Useful Stuff.
  • Tascam Master
  • 19,396 Answers
You need to save all your songs, then you re-format the tascam hard drive, I can post the full procedure, but I need to get the user manual first.
Hi im new to using the effect send on my tascam 2488 neo. How do i set the connections? how dose it work?
I think if you had the manual you would know the answers.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 05, 2011 | Tascam 2488 Portastudio Multitrack...
It keeps locking up
I had a similar problem before mine completely crashed. Make sure you back up your data and have a look at the space you have left on each of your three partitions. Try to delete any unused track space before recording again.
Nov 17, 2009 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
176 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
