Question about Motorola Mobility H700 Wireless Headset
H700 Headset I have the H700 headset which worked perfectly with my Samsung D500. I have recently got a Samsung Z560 and am unable to pair headset with it. It is no longer paired to the D500 so can't understand what the problem is. Also don't get the pairing purple light just flashing blue. Phone just says unable to find devices. Can anyone help.
  • Lesley Wilder Jul 23, 2007
    Have read solution will try tonight, as been away for weekend and only just read emails.
First off, you want to have the H700 fully charged up and it's probably good to have the Moto SLVR fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the phone. This one worked for me.
Posted on Jul 22, 2007
Is the Samsung bluetooth turned on?
Posted on Jul 17, 2007
6ya staff
SOURCE:
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
I have my second motorola H700 headset paired to a samsung m300 phone. The problem is with my first headset after the pairing of the two, any time the headset was closed the bluetooth icon would go black...
Some phones allow you to set the options for the device in the bluetooth menu for each device. These options include auto authorize which is what you would be looking for to enable for your new headset to auto connect. I'm looking at the Samsung m300 user guide, but it doesn't mention this option, however it may be in the menu as an option when you select the device under the bluetooth menu.
Feb 24, 2010 | Motorola Mobility H700 Wireless Headset
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
H700 / Samsung Blade: WILL pair. Won't Connect!
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
The
Jun 15, 2008 | Motorola Mobility H700 Wireless Headset
TRYING TO PAIR THE H700 TO MY TMOBILE WING
Just have to re-pair it.With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 28, 2008 | Motorola Mobility H700 Wireless Headset
LG RUMOR
Jan 26, 2008 | Motorola Mobility H700 Wireless Headset
Connecting my H700
If you have it paired with another device, shut that device down first.  With the boom closed on the headset, hold the center button down until it turns a steady purple, then open the boom on the headset.  Then click on find device through your Blackberry.  Enter code 0000.  It should work for you then.
Mike
Oct 01, 2007 | Motorola Mobility H700 Wireless Headset
Problems with headset and hearing anything
I am having the exact same problem today and I paired mine with a Treo Palm 700 on yesterday and it worked perfectly then. UGH!
Jul 12, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
142 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
