Question about Moen Home
Moen toilet repair kit M5305 - Moen Home
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: We have installed a new fluidmaster toilet repair
Hi dona way,
There are 2 things that can be adjusted to stop the toilet from running. It will keep running as long as the water level does not maintain itself.
First, is the valve at the exit hole in the tank seated completely. You may have to adjust the chain, or make sure the chain doesn't hangup so the valve seats well. Did you clean the opening well before putting the valve on? If there is calcium build up, you may have to sand the opening a bit to give a nice smooth level surface.
Second, Is the water running because the float is set too high and the tank fills past the overflow pipe opening. This also can be adjusted. The instructions that came with the kit should explain how to do this.
Good luck,
I hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Posted on Mar 28, 2011
IM NEEDING VERY DETAILED PHOTOS OF THE "NEW MOEN TOILET REPAIR KIT M5350". I NEED PICTURES & DETAILS ON HOW THE TOP OF THE VALVE UNDER NEATH THE GRAY TOP THATS IS ATTACHED TO A BLACK ALMOST LIKE A STOPPER...
Go to the following link:
http://www.moen.com/
Click on the "Support" menu near the right corner of the page.
Then click on "Parts & Instruction Sheets"
Then enter the model of your toilet in the search box.
There is also a menu selection for getting replacement parts for your toilet if you need to; just enter the part number or model number in the search box.
Good luck on your project.
Dec 02, 2013 | Home
I JUST RECENTLY BOUGHT A MOEN TOILET REPAIR KIT M5350, & IM ACTUALLY JUST REALLY KIND OF CURIOUS AS TO HOW IS EVERY THING UNDER NEATH THE GRAY TOP OF THE VALVE SUPPOSE TO LOOK, OR BE PUT TOGETHER? (STEP BY...
Dec 02, 2013 | Home
Moen dn8408ch fell off the wall post. How do I reattach?
There should be a set screw on the bottom. Position the holder on the mounting plate and re tighten screw. It takes a pretty small flat head screwdriver. Here is the pdf format manual for this holder.
http://www.moen.com/shared/pdf/dn8408sp.pdf
May 15, 2011 | Moen DN8408CH Preston Toilet Paper Holder,...
Purchased a toilet repair kit and the unit continually runs - slowly - like it doesn't fill up all the way. When you just touch the arm, it stops running. Any suggestions?
Dump some cake dye in the tank and it will go into the bowl...this shows that the flapper is not sealing properly....find out what is wrong with the flapper and get it to seal...
the flapper is the thing that goes over the big hole and lifts up when the toilet is flushed...
heatman101
Feb 02, 2011 | Moen Home
The moen fill valve #5300 will not fill up after flushing the toilet
contact Moen they will send you a repair kit for the valve.
Dec 12, 2010 | Home
How to install this tank lever in a side mount style tank? Is there any web where I can find the instructions? It comes for front installation, don`t know how to change the pieces so I can install it on...
Call Moen customer service. They should be able to help you.
here are the contact numbers.
Call: 1-800-Buy-Moen (1-800-289-6636)
8:00 am to 8:00 pm EST Monday thru Friday
8:00 am to 6:30 pm EST Saturday
Closed on Sundays and all nationally observed holidays.
To contact Moen Canada call: 905-829-3400
Apr 20, 2010 | Moen Brantford YB2201 Toilet Tank Lever -...
Home Logo
50 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
