Question about Whirlpool Washing Machines
I have a Whirlpool front loader Model GHW9150PW1.The drum seems to be wobbling real bad and dragging the bottom of the washer,can you help.
Drum seems to be off center,the front drum is moving off center about 2 too 3 inches.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
First, remove the 2 screws that hold the bottom front kick-plate on and remove the plate. Look to see if any of the shocks have come loose or broke. Post back your results.
Posted on Jan 21, 2013
  • 185 Answers
SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Posted on Mar 28, 2008
aborcass
  • 2651 Answers
SOURCE: need a manual
here you go
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182271.pdf
Posted on Apr 29, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
SOURCE: My whirlpool front loader washer leaks water
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Posted on Nov 20, 2009
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Older and making more noise....
There are four "balance" wheel type devices that hold the tub/drum centered. They wear down and become uneven causing sounds and other things to happen! Go to sears web page for parts. Look for the Counter weights and shock absorber here:http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-GHW9150PW1/1198/0153200/W0512128/00005?blt=06&prst=&shdMod=
Jan 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The drum on my front loader is dragging and wearing against the plastic which is shreading off
Sounds like one of the support arms holding the inner drum has failed. It is very expensive to repair, most of the time a new washer would be the cheaper than the repair. Sorry
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hf error message
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Washing Machines
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Tub has a wobble in it . front seems loose.
Could be loose bolt @ back of pulley or Drum bearing gone which makes drum very noisy on spin expensive to fix..
Oct 03, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
