Question about Poulan 2150 Chainsaws
How to clean the muffler on poulan2150. - Poulan 2150 Chainsaws
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
First of all, take the muffler off. Get a torch. Propane bottle with a torch adapter. You can get this at any auto parts store, home depot, Walmart. Take out the spark arrester (SCREEN) and just start cooking it. All the oil will burn off. This works great!
Posted on Jan 23, 2013
Why is oil coming out of the exhaust pipe?
If your previous turbo had leaked oil into the exhaust system there would still be oil residue left in the system. (1) The catalytic converter/converters would need to be replaced if you have one plus any O2 sensors. (2) If your muffler/mufflers are a glass packed type, replace it with a new one. If muffler is a chamber type you can clean it with a solvent or replace your call. The muffler/mufflers are were most of the oil will be pooling. (3) Clean as much of the exhaust as you can with the solvent that you used to flush the mufflers with.
Feb 05, 2015 | Cars & Trucks
PP2075 starts with the muffler off but not with it installed. Muffler is clean - screen is clean - center facing the right way. Good fuel etc....
mufflers can be clean and still not work properly. After removing muffler and unit runs then change your muffler and clean your exhaust port while doing so
Sep 18, 2014 | Garden
Where do i find idel jets in carb on a poulan2150 2.1C.I chainsaw
The jets will be under alluminium core plugs, special tools are required to remove them, this should be left to a chainsaw shop as with the wrong tools the carb body can easily be damaged.
Jul 21, 2013 | Garden
How do you clean out a stopped up muffler on Homelite d3300 chainsaw
Hal:
I remove the muffler, and clean it with a spray bottle filled with rubbing alcohol... make sure that the alcohol is completely evaporated before starting the saw with the muffler on it. You can also use carburetor cleaner. An old toothbrush comes in handy also.
Jan 02, 2013 | Garden
Poulan 1950 muffler problem
i have found that myself pried open the openings and burned off the screen with a torch
Sep 05, 2012 | Garden
Replace muffler on poulanpro 262 42cc
there is two bolts on the front of the muffler that hold it on remove the bolts and the muffler will come off most muffler problems are carbon build up inside the screen it is made to open to clean the screen
Jun 30, 2012 | Garden
My weed eater sounds like its ready to die, looses power runs like it ca,nt get eithr gas or air
if it's an older unit start with pulling the muffler and cleaning exhaust port and spark arrestor. while muffler is off sta.rt the unit and check for improvement. if no improvement clean & adjust carb. if improved with no muffler, test again with muffler installed. if unit goes back to running poor replace muffler.
Jul 12, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
My ryobi weedeater will start in the choke or low position but will die when you switch it to the middle or high position.
It's the muffler. Everyone thinks fuel, carburetor, mixture. They're wrong. The muffler is clogged and the unit can't be tuned to high throttle until you clean it.
Steps: Remove the back housing to access the muffler. You may want to remove the gas tank to avoid a spill. Remove the muffler (2 large screws). Remove the muffler door (3 small screws). The screen should be cleaned using a pin (poke out any hardened material). Most important: The muffler door is 2 parts. Pry it apart and scrape off the burnt carbon that is clogging the exhaust path. Re-assemble and start.
May 02, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer runs on half choke only
Apr 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite 25cc muffler problem - won't run
The best way to do it is to remove the screen. Take a small screwdriver and some carburator cleaner and make sure that the exhaust is clear. Use a wire brush and clean the screen. I personally remove the little screen on every weed eater I have. Not politically correct, but effective, because those screens just keep getting clogged up and causing problems. Good luck and hope this helps you!
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan 2150 Chainsaws Logo
37 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
