Question about Echo Back Pack Blower Rack Fits Stihl Shindaiwa Red Max
Eb480 shindawaia blower oil to gas ratio - Echo Back Pack Blower Rack Fits Stihl Shindaiwa Red Max
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
Posted on May 26, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the gas;oil ratio for the echo 403T backpack leaf blower.
50 to 1
Posted on Nov 01, 2009
taran_2005
  • 10515 Answers
SOURCE: what is the correct oil to gas ratio for an Echo
Fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil.
Thanks!!
Posted on Nov 04, 2009
Testimonial: "Very prompt answer."
bulldogchief
  • 388 Answers
SOURCE: gas oil ratio mix
40:1 is the standard. You can achieve this by mixing a 3.2 ounce bottle of two-cycle oil with a gallon of gasoline. The best way to do that is to buy a one gallon gas can, add a little bit of gas then pour the entire 3.2 ounce bottle of oil into the tank, swish that around for about 5 seconds then fill the can the rest of the way.
Posted on Dec 03, 2009
  • 514 Answers
SOURCE: What is the oil and gas mixture ratio for a gas
per http://www.echo-usa.com/faqs/ it 50:1, there is a chart at the site that shows how to mix it.
Posted on Oct 12, 2010
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is the oil mix for 2 gallons of gas for a 2 cycle gas leaf blower
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Aug 11, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Blower starts and runs for 5 seconds and cuts off. Is it an oil to gas ratio. Is is 32:1 or 40:1? For the Echo PB250 gas blower.
I don't think the oil-gas ratio will cause that problem. Did you check to see if the fuel lines or fuel filter is clogged?
Aug 15, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Optimum oil to gas ratio?
Ratio is 40 to 1
Please give feedback
Feb 15, 2010 | Poulan Garden
Gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
Jan 10, 2010 | Garden
Oil/gas ratio for a modle UTO8110 homelite leaf blower
I am not positive but we have stihl equip. and some other 2 stoke brands about 35 pieces and we run 32-1 in all of it and have never had any problems that should work for any brand
Jan 27, 2009 | Homelite Consumer Products MightyLite...
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
Jan 09, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
Echo Back Pack Blower Rack Fits Stihl Shindaiwa Red Max Logo
35 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
