How to open remote control Sony RM-ED016 - Televison & Video
5 Suggested Answers
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
  • 19 Answers
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
SOURCE: TV remote RM-ED002 for main TV works fine except volume
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Posted on Nov 03, 2009
  • 208 Answers
SOURCE: Unlock code from remote RM-X96.
http://www.fixya.com/support/t351405-sony_rm_x96
Posted on Mar 19, 2010
How to open Sony remote control device RM-887
and why does it need opened . not made for self service .
Dec 23, 2014 | Sony Televison & Video
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Open remote control sony RM-GA011 for cleaning
how can i open remote control RM-GA011 SONY REMOTE
Oct 01, 2012 | Sony Televison & Video
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
Aug 24, 2009 | Televison & Video
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Televison & Video Logo
2,012 people viewed this question
Top Televison & Video Experts
