Question about Garden
I have a Rotical Supermatic rototiller I need a spark plug for it the old one is called a "lawn mower 4051" if any one can help that would be great! the tiller is probably 25 years old but runs gre
  • Dana Carbone Jan 21, 2013
    how do I know when someone helps with my question?
    Sergeant:
  • 322 Answers
I crossed that number and it comes up as an autolite plug. The NAPA number for a champion plug is 805 or an NGK 7928. Take the old one in and compare them but that is the best I can do
Posted on Jan 23, 2013
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 10865 Answers
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
Posted on May 06, 2009
  • 246 Answers
SOURCE: yard man gas push mower starts but wont stay running
Hello jusapup68:
>>Did you Soak the Carburetor when you Cleaned it?
>>If No, then the Carburetor can Still be the Problem.
>>Does the Engine Start and Quit if you Pour a Small Amount (1/4 oz of Gas into the Carburetor and Try to Start the Engine?
>>If Yes, then Soak the Carburetor Overnight.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select Shop Online Parts and Accessories. Now Select the Model Tab. Select the OEM (MTD) and Enter the Model Numbers. Now Double Click on the Model in the Results Area.
>>Have you Checked the Spark at the Plug?
>>Here is a Basic Instruction File I am in the Process of Making. It will Might Say Mower, but a Snow Thrower/Blower is Powered by the Same Type of Engine, so the Diagnostics are Basically the Same. >>***Here are some Diagnostic Instructions to Do on the Engine to Locate the Cause/Cure for a Hard/Not Starting Engine. This Does Not Include a Problem with the Valves. If I Suspected the Valves are Involved, then a Separate File for the Valves will be in this E-mail. This is a File in the Making, so Any Input is Appreciated.
>>1- Check the Spark. If Not Firing, then Replace the Plug.
>>2- If the Plug is Firing, then First, Pour a Small Amount of Gas (1oz) Into the Carburetor Throat with the Throttle at Full. With the Throttle Still at Full, Try to Start the Engine. If the Engine Starts and Quits, then Make Sure the Gas is Free Flowing to the Carburetor. If the Gas is Free Flowing, then Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl, Float Pin, Float and Needle Valve and Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. Then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air. Install New Parts if Required.
>>3- If No Fire at the Plug, then Remove the Coil Shut Off Wire from the Kill Switch at the Engine Stop/Brake Bracket (where the End of the Stop/Brake Cable Attaches at the Engine). Check for Fire. If No Fire, then Remove the Blower Housing and Remove the Ground Wire from the Coil. Check for Fire. If Still No Fire, then the Coil is Bad. *On Some JD Model Mower the Engines Use an Igniter. Remove the Igniter and Coil and have your Local JD Dealer Test them for you.
>>* **On Models with Point Set, the Condenser is Bad and the Point Set and Condenser should be Replaced as a Unit. Make Sure the Point Set Plunger is Fully Extended when Setting the Point Set Gap to .020in.
>>** If there was No Response from the Engine When the Gas was Poured Into the Carburetor Throat and the Plug was Firing, then Check the Compression. If the Compression is Good, the Carburetor has Been Soaked and Cleaned and the Plug is Firing, then Check the Flywheel Key. If the Key is Damaged, then the Plug Firing is Incorrect to the Position of the Piston During the Compression (Power Stroke).
>>*** On the OHV and Some L-Head (Flat Head) Engines there is a Compression Release. The Exhaust Valve Clearance has to be Opened to .020in for the Compression Release Not to Operate; in Order to get a Correct Compression Reading.***
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
mowerman1857
  • 389 Answers
SOURCE: Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
Where is the spark plug
Where is the spark plug In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Tips Replace Lawn Mower Spark Plug
How to Change Push Mower Spark Plug
How To Change Spark Plug on John Deere LA 105 Lawn Tractor or Riding Mower
How to change spark plug on craftsman LT1000
Mar 27, 2016 | Garden
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Rototiller pull cord stuck
Try removing spark plug and pulling cord slowly to see if oil has entered the cylinder.
Feb 05, 2014 | Garden
Magnetron replacement
Go to a mower dealer and tell him what motor you have and he will have a listing for the B&s motor spark plug.
Oct 06, 2013 | Briggs & Stratton Measuring Tools &...
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Cleaned the Briggs & Stratton Riding Lawn Mower's head and valves. Put it back together and it refuses to start, get good starting try, no joy. Checked the spark, great! Checked the gas- great!...
did you usae a new head gasket and clean the old gasket off? does the plug get gas? you must have spark, fuel, compression and timing in order for it to run. also did you gap the coil to flywheel spacing?
Jul 08, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Jul 03, 2009 | Garden
My lawn mower starts uo then shuts right back off
The three most common causes (IMHO) of your problem are: 1.) Carb (dirty or gunked up) 2.) Gas (old, maybe has water in it, or wrong octane/type. ie., no e-85 in mower) 3.) Spark plug (worn may need replacement, or gap checked) Lawn mowers are simple internal combustion engines. Like any other, all they need is spark, air/fuel, and compression to run. Think about those three things as you trouble-shoot. I hope this helps.
Jun 14, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
No spark
If your engine is 11 years old it will have points @condensor under flywheel there are two wires coming from the condensor one goes to the coil and the other goes to a ground switch thats most of the time on the throotle linkage,if that wire is grounded against metal there will be not spark . the gap between coil and flywheel is 10 thousands (you can use an index card to set it .
May 16, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
