Motorola irc550 remote - sat button flashes twice when i press guide tried pressing mute and enter together but that didnt work. Remote will not work with receiver at all.....help!!
Also replaced batteries and left them out for a few minutes that didnt help either :(
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
SOURCE: Gyration remote control will not sync with the rf receiver.
I had this issue and this is what I did.
1: Control panel
2: Double click Mouse (To access "Mouse Properties)
3: On top click Hardware
4 Check how many hardwares you have and one by one highlight them and click properties and update the drivers.
Try that and post any message
Posted on Feb 17, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 5 Answers
SOURCE: I m trying to program my RC64 remote for Direct TV
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Posted on Jan 10, 2010
Testimonial: "Thank you thank you thank you!!!!!"
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    I can't find the code list anywhere for my universal remote. it's a motorola universal remote used for a sanyo tv, I'm not sure why it's so difficult to find. The codes for the remote include...
    this should work
    http://nsegainkc1.bellaliant.net/knowledge/Docs/Internet/IPTV/Remote/Remote_Control_User_Manual.pdf
    1. Power on your TV.
    2. On your Motorola remote, first press and hold the TV button; then, while holding the TV button, press the OK button. Release the buttons together. The STB, TV, DVD, and AUX buttons flash twice.
    3. Using the number buttons on te bottom of remote, enter the 4-digit setup code for your TV. This code can be found in the pocket pamphlet called "Motorola Remote Control User Guide" received when service was first installed. When you enter a valid code, the TV button flashes three times.
    4. Point the remote at the TV and press the POWER button. If the TV does not turn off, repeat steps 2 and 3 for each code listed for your TV until you find a code that works.
    Sep 14, 2010 | Televison & Video
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    I want to find the Sky remote code for this Tv.
    Just got an LG 42LH2000 and code 0206 works
    May 16, 2009 | LG Televison & Video
    Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
    Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
    Mar 26, 2009 | Sony Televison & Video
    Thomson Digital TV Recorder DTI 6300-16 volume control
    The manual is not very clear.
    The volume control will work after entering the code for your TV make.
    Press TV
    Press AV and OK together and wait. The TV button will flash twice eventually.
    then using the numeric keypad enter the code ie 0680 for Panasonic,
    a list was provided with your instructions.
    On entering the code the TV button will flash twice again t confirm.
    Now the volume of the TV can be controllled using the buttons on the Thomson remote.
    Teletext and other functions like "mute" are now present.
    peterh
    Dec 25, 2008 | Televison & Video
    How do i key in code for digibox
    TO PROGRAM THE remote USING THE 3 DIGIT CODE:
    1. Turn on the TV receiver
    2. Press TV on the Sky Remote Control
    3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
    4. Enter three digit code from list for the receiver (early versions now flash twice).
    5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
    6. Now press the STDBY button and test other functions.
    Repeat if necessary until a code is found that works most common functions.
    TO PROGRAM THE remote USING THE 4 DIGIT CODE:
    1. Turn your TV on.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press tv on your Sky remote control again.
    5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
    If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
    Dec 19, 2008 | Computers & Internet
    Televison & Video Logo
    61 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
