Question about Packard Bell Computers & Internet
My packard bell pc model alt-c02 wont turn on ?
I turned it off last night and it wont turn back on. Can anyone help? Thanks.
  • Packard Bell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 20, 2013
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
Bassplyr1
  • 77 Answers
SOURCE: packard bell imedia alt-col2 just keeps beeping on and off
Find out what's making the noise first. It's either your fan or your hard drive. Check to make sure the noise your're hearing isn't your fan cutting into one of your wiring harnesses. That could be why you have the video problems. If it's your hard drive making the noise, that means it's on it's way out and you should immediately back up your files on disk and replace the drive before you lose everything.
Posted on Jul 15, 2009
tennison
  • 13 Answers
SOURCE: My packard bell pc just stopped working
I think This is BIOS problem so
open CPU box and clear bios settings...
oterwise change tha mother board
TENNISON J
Posted on Aug 29, 2009
SOURCE: wireless button on packard bell easynote MV35-202?
Fn / F1 or some models are Fn / F2
Posted on Oct 06, 2009
  • 383 Answers
SOURCE: my packard bell ixtreme 5830 wont turn on. the
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Posted on Jun 12, 2010
Packard bell - wont recognise wireless adapter
i have the same problem, mine wont even recognise the adapter at times.
Dec 14, 2011 | Packard Bell Computers & Internet
Can t turn on my webcam
Hi
have a look at the top row of keys to see if there is a key with a picture of a camera
if so press it or press FN+ that key or ALT + that key
or
go to control panel find scanners/camera and look for the web cam and press it
o
go to start
all programs
packard bell
user guide/info
and see if that shows you how to activate the web-cam
there are so many makes and models and they can all work in different ways
hope you can sort it
many thanks
Jun 14, 2011 | Packard Bell Easy One Silver 2101 Notebook
My packard bell ixtreme 5830 wont turn on. the light stays orange instead of green can anyone help
Jun 11, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
Hi my Packard Bell desktop isn't booting up correctly. I get power on signs, the keyboard light is on and I can hear the PC fan, but there's nothing on the screen. I've tried restarting but it repeats the...
kinda stupid answer but check the back make sure your moniter is plugged in.if it is it might be your motherboard ive had this problem with a compaq before it turned out to be the mother board something was broken inside it
Oct 05, 2009 | Packard Bell ixtreme 9222 (P491000102) PC...
Packard Bell Easynote SJ51 Problem!!!
I have _exactly_ the same problem, my Packard Bell SJ51 notebook is also 2 years old.
Sep 25, 2009 | HP Computers & Internet
Packard bell easy note
You may need to get a new power supply!
May 05, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Packard bell utow co20
Please look on the case of the PC, fron back & sides. There should be a model number. (There is no such number you posted, Packard Bell UTOW CO20).
Mike
Jul 06, 2008 | Packard Bell DR724 Motherboard
Computers & Internet Logo
308 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
