Question about Car Audio & Video
SC-900 does not play CD's Burned from Computer
The SC-900 will not play discs burned from a computer
    Top Expert:
  • Car Audio & ... Master
  • 43,132 Answers
Check whether the record and play formats are compatible. For example a CD R/W disk may not play
Posted on Jan 20, 2013
Why won't a cd disc that I "burned" play on my Panasonic CD Stereo System?
Try cleaning the lazer lens in the Panasonic cd player. Dust can cause it not to read the disk.
Nov 11, 2014 | Audio Players & Recorders
I burned a disc of music but doesn't play on my Panasonic CD Stereo System.
Some players are like that! You need to experiment with different makes and speed settings when recording!
Burned cd will only play on my computer. How do I get it to play other places
It depends what setting you used to burn the disc. Some will only play on certain players. Many people don't also have the right CODECS to play video files with their media players. But they can download CODEC packs from the internet for free.
Sep 12, 2014 | Roxio Easy CD & DVD Creator 6...
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Front panel on machine just reads ..disc not finalised.what does this mean please?
Are the discs ones that you created (burned), someone else burned, or commercial discs? The message of disc not finalized usually appears when you put a CD or DVD from one unit into anther without closing (finalizing) the disc. The finalization step doesn't matter if the disc is being moved between computers with compatible OS versions (for example: XP through Windows 7). However, any other device will need this procedure completed.
Take the disc back to the unit (computer or other burner) where the disc was burned. If the computer uses Windows, put the disc in the optical drive. Open My Computer (Computer) depending on the OS by double left-clicking on the icon on the desktop. Right click on the optical drive and select Close Session.
If you created the CD on another machine, check the details for that device.
Note: you should double-check that the format that you burned to disc is compatible with this CD player. Not all models support MP3 files. On my own older CD player, I had to burn WAV files without gaps in a Disc At Once format to get the discs to play without skips.
I hope this helps.
(if the discs were commercial discs or have been finalized, I would expect a different error. In that case, I'd suspect a tracking problem and a "No Disc" error.)
Jun 15, 2012 | Marantz Audio Players & Recorders
My Verbatim DVD +R DL disc burned on my NEC 2510A DVD-RW will not play in a desktop DVD player but will play the computer it was burned on. The computer is running Windows 7.
It;s possible that you may have left the disc open or re-writable. Check this first.
The settings will be located in the software you used to burn the disc. Easiest would be to start a new burn session and read the available settings throughout the window prompts. It may also be located in advanced settings, if you don't find it this way.
Jun 14, 2011 | NEC ND-2510A DVD±RW Dual Layer Burner
HOW I DOWLOAD MY COMPUTER PICTURE TO A CD
  1. Check your computer to see that it has a CD or DVD drive that is capable of burning CDs. This drive may be built into your computer or an external drive. Either type should work equally well.
  2. Make sure you have a CD that can be burned. There are two types of CDs that you can use.
    1. A CD-R (Compact Disc-Recordable) is a Write Once Read Many (WORM) optical medium. This means that once the disk is burned it can not be erased. This type disk is usually used for permanent storage. For example; a music CD, a picture CD, or any other type of data that you want to keep permanently.
    2. A CD-RW (Compact Disc ReWritable) is a rewritable optical disc format. This type of disk can be burned, erase, and then burned again. This type disk is usually used for temporary data storage.
  3. Decide on the type of CD you plan to burn. There are many different types of CDs that can be burned and how you proceed depends on which type you are going to burn. The major types of CD that can be burned are:
    1. Music. This type of CD is the type of CD that is normaly burned for use in a home or automobile CD player.
    2. Data. This type of CD is most often used to store files that can be used by a computer. This type of CD can not be used in a standard home or automobile CD player. They are formatted using the "ISO9660" format, which cannot be read by a standard CD player.
    3. MP3. This is a data CD containing only mp3 compressed music files. Because it is actually an ISO9660 data CD, not all CD players will be able to play it. This type of CD can contain a much larger number of songs than a music CD but can only be played on a computer or CD player specifically designed to play MP3s.
    4. Disk image. A disk image file is a file that contains an exact copy of a disk. The most common type of Disk image is an .ISO image. Disk images are usually used for storing an exact copy of a CD on a computer. By using a computer, one can burn a CD from an .ISO image and create a usable CD.
    5. Ripping. Ripping a CD is the process of taking the audio off of one CD and either storing it on a computer or burning it to a second CD, thereby making a copy of the first CD.
  4. Decide on the software you want to burn your CD with. There are many different programs that are designed to burn CD's. Some are built into the computer's operating system, while others are individual programs. These programs range from very simple to very complex. Some of these are free, while others have to be purchased.
  5. Burn your CD. Burning your CD is as simple as running the software that you are going to burn your CD with, putting a CD into your CD burner, selecting the data to be burned, and then telling the program to burn the CD
Feb 02, 2011 | Computers & Internet
CD player won't play MP3 CD's?
I have had similar problems in the past - on one computer discs burned using nero were unreliable but using Windows Media Player they were fine and on other computers the Windows programme was useless and produced unreliable inconsistent results.
I suggest you experiment with different burning software and maybe suspect the drive you are using might be past it's best.
I have several cd players in my vehicles and around my home. Only a couple of them will play all the discs and most of them are very choosy and will only read premium price shop bought discs and it is a waste of time trying to play a discount store or freebie disc, or many of my computer burned discs.
I don't know what the differences are - maybe it is the software or the power of the laser burning the disc or the sensitivity of the reading laser, but there are many differences in there somewhere. The situation is very frustrating...
Mar 19, 2017 | 2000 Nissan Maxima
Dvd will not play in dvd player but will play in computer
I don't know if I really find the solution but several burned discs I decide to burn a poor disc 8x instead my emtec 16x and voil'a the disc go on my SC-HT70. I suppose it doesn't support new type of discs with higher velocities even burned at a lower velocity (4x). If any one have another solution please let me know.
Also I know we can upgrade firmware of Panasonic but it can only be done by a technician and it's very expensive.
Thks
May 18, 2008 | Panasonic SC-HT70 System
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
