Question about Alpine IVA-D300 Car DVD Player
Door speakers don't work and it shuts off after five minutes
The Door speakers don't work at all and after five minutes of being on the radio shuts off.
    Scholar:
  • 116 Answers
Shorted speaker wiring?? Check with a multi meter to make sure that speakers test at 4ohm and no wires are shorted to ground.
Posted on Jan 28, 2009
Why my front speakers don't work
is this a stock radio? i had a chevy radio that tone of the channels blew out and no front speakers. also check the door speakers to see if the wires aren't corroded from moisture .
Mar 27, 2013 | 2007 Chevrolet Cobalt Coupe
97 DODGE 1500 CHASIS WIREING DIAGRAM
probably a bad ground connection on the speaker. remove door penal and speeker and inspect.
Mar 24, 2013 | Cars & Trucks
Radio stops working after about five minutes . I turn it off and back on and it works for another five minutes . Over and over again.
My il did the same thing for a long time. I found a wrecked il in a junk yard and bought the amplifier in the trunk for $50. They are over a thousand at the dealer. Problem solved!! Ray
Nov 25, 2012 | 2000 BMW 7 Series
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
Aug 24, 2011 | 2004 Pontiac Montana
Both of my front door speakers don't work in my
With the lack of information provided all I can suggest is ..
1. are the speaker wires connected at the radio? 2. are there rear speakers and if so do they work? 3. make sure the fader control isn't set to rear, this would shut your front speakers off
May 07, 2011 | Pioneer Car Audio & Video
CD Player not workinig
Try using a cd player cleaner disk, then remove the radio fuse in the fuse block wait about five minutes then re-install. This is done to restart the radio. If that don't work disconnect the negative from the battery, wait five minutes then reattach, this will restart the cd player for sure. This will also restart the car computer just so you are aware.
May 12, 2009 | Car Audio & Video
Screen is frozen on my jensen vm9412 help plzzz
No idea, try restarting it. Remove the radio fuse in the fuse block, wait five minutes then reinstall. If that don't work remove the negative from the battery, wait five minutes then reattach. This will restart the unit for sure, it will also restart the car's computer just so you're aware. Let me know how it goes.
Jvc kd-dv 4306 is on standby mode not turn on
Try taking the radio fuse off, where all the other fuses are located, wait five minutes and re-install. What you want to try to do is restart it. If this don't work, remove the negative or ground cable from the car battery, wait five minutes then reinstall.
May 07, 2009 | Car Audio & Video
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Alpine IVA-D300 Car DVD Player Logo
66 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
