Question about JVC RX-6010V Receiver
I want more sound in rear speakers - JVC RX-6010V Receiver
Why is there no sound from rear speakers?
One of the buttons you pressed probably disabled surround sound
Nov 03, 2015 | Denon AVR-791 7.1 CH A/V Home Theater...
Creative SB X-Fi titanium rear speaker out problem
Hello.
This sound card it is well compatible and all you have to do its depending on your OS update and reset the sound properties to get the full reestored sounds of all channels.
Hope this hint helps
Carl
Apr 02, 2017 | Creative Technology Creative Labs Sb0880...
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
No sound from Rear Speakers
Ok, so we know the connections are correct, the speakers all work properly.
The only other thing I can think of is: is your PC actually sending signal to the rear speakers? Have you set it to 5.1 surround, and are you playing something in surround sound? The best way of checking (personal preference) is use some kind of racing game, reverse into something and you'll get a broken window effect in the rear speakers.
So, check to see if your PC is sending the rear effects, double check to make sure the actual speakers work (you could plug an MP3 player into the rear speaker input.
If this doesn't help, feel free to reply.
Jan 11, 2010 | Audio Players & Recorders
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Feb 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Rear speaker not working
If you did the 5.1 sound test and the rear speaker works, sometimes you have to see in your software speakers settings,probably you need to change to 5.1 speakers
May 28, 2007 | Dell WL6000 Computer Speakers
JVC RX-6010V Receiver Logo
32 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
