Question about Reebok Vista Treadmill - RBTL13305
My reebok tr2 premeir run tread mill has wires disconnected from under the motor hood can anyone give me a picture or diagram on which and what wires go where !!!!!!!!!!!!!!
On my reebok tr2 premeir run, running machine i have wire that have come disconnected from the circuit boards underneath the motor hood can some one give me a picture of what and where the wires go the their respective circuit boards colours of wires and so forth ?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
See the diagram attached and fix it. God bless youmy reebok tr2 premeir run tread mill has wires dis - 1_21_2013_6_19_10_pm.png1_21_2013_6_19_41_pm.jpg
Posted on Jan 21, 2013
2 Suggested Answers
  • 31 Answers
SOURCE: reebok 11300 treadmill I have had
The wiring diagram is under your motor hood in an envelope. Also look at the other end of the harness - the wires are in the same sequence. Just be sure to get all the insulation out of the connector before trying to reinsert the wire. Must insert wire with insulation on it. These are the red connectors I am talking about.
Posted on Jan 15, 2011
Instruction manual required
http://userguides.50webs.com/reebok_tr2_manual.html Reebok Tr2 Manual
Feb 17, 2014 | Reebok TR2 PremierRun Treadmill
Reebok premier run tr2
1) can be some easy matter:see the video and make the final decision
Jun 06, 2013 | Reebok Exercise & Fitness
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
I have a reebok tr2 premier run treadmill i moved house so needed to strip it down now im having trubble where the wires go on the circut bord near moto . got 2 blue leads 3 white red and black . the black...
1) See the diagrams+block attached:
and proceed according. otherwise, you must call some service tech. To due the problem with wiring diagram.God bless you
Jun 09, 2012 | Reebok TR2 PremierRun Treadmill
After i run a mile or so the reebok irun will cutout how can i solve this problem
Dear Sir:
Please LUBE The lack of this produce enough friction between deck vs deck belt. this cause to shut down the machine.
After you lube RUN the software calibritation for diagnose and troubleshooting.
2) Test the main motor measure the input voltage.if there are the problem is the motor need repair.
3) Test the main board for output for input voltage motor, if there are Not the board is Faulty.
sincerely. God bless you
May 02, 2012 | Reebok Exercise & Fitness
Reebok Treamill TR2
Dear Sir:
You need LUBE the machine according with instruction manual for maintenance. if you do not have download free www.fitness.manualsonline.com or www.iconservice.com
The friction is enough by lack of lube, shut down the machine for protecting the electronic system.
Test the main motor ,drive belt,
After that RUN the software calibration for diagnose, troubleshooting and fix it.
Apr 26, 2012 | Reebok Exercise & Fitness
Tr2 motor will not run,used 24v battery to test motor,runs ok.what could it be
Dear Sir:
Try to run the software calibration for easy diagnose and troubleshootin.
See my personal TIPS FOR HELP.
However the main motor board 2) main motor can be faulty.
measure the input voltage to the main transformer. 2) measure the output from the main motor board.
Apr 09, 2012 | Reebok Exercise & Fitness
I started my reebok ice treadmill (REM-RE10301I) manufactured date FEB, 2009 and it began to spark and tripped my electric, i turned it back on and everything works fine apart from the belt will not move,...
First of all check the Fuse in the Motor control board. If it faulty then replace the same. If the fuse again blews the the you have to check the motor and its driver board. Using a car abttery you can check the motor. Connect the red wire from the motor to possitive terminal of the battrey and the black wire to the negative terminal. If the motor is ok the it will run without any trouble. If not then you have to replace the motor. If the motor is working perfectly then you have to check the motor control baord. It is available as modules. If you want to repair the motor control board then, You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will not run or will run at high speed. . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference
ajin_g_95.jpg ok
Sep 18, 2011 | Reebok Exercise & Fitness
Reebok i run stopped working after 5 mins power light on . display screen blank
it sounds like it may be the fuse on the motor circuit board? if you unscrew the motor cover and have a look inside(ensure you have turned the power off) you will see the circuit board and the fuse is in the middle. take it out and have a look to see if it is intact. go to Maplins and ask for a replacement as it is not a standard fuse, it is a 'time delay fuse'.
if this does not resolve the issue, you may need a replacement motor circuit board (around £40) which is very easy to replace. if you need help doing this let me know and ill guide you through it.
Apr 16, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok Vista Treadmill - RBTL13305 Logo
601 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
