My acer 5920 keeps starting in System Recovery Options
S/N LXAKV0X37974709CB42500 SNID:74704011625
  • 27,725 Answers
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Posted on Jan 20, 2013
the terrier
  • 94 Answers
SOURCE: I need DVD System Recover Laptop Acer Aspire 5920-6168
hi techpa
you may find it here http:\\global.acer.com/support/downlowds.htm
Posted on Oct 26, 2008
  • 10 Answers
SOURCE: acer asire 5920 wont boot up cant get to windows
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Posted on Jun 16, 2009
shahabdun
  • 249 Answers
SOURCE: VISTA boot stop and shows ACER recovery screen .
Restart PC
Press F8 as it restarts.
Select Safe mode and see if it workes.
Restart PC again.
Select "Last known good configuration"
If this does not work either,
Do a system restore.
Posted on Jul 19, 2009
Tech_Mania
  • 239 Answers
SOURCE: acer 5920 start up
Try to upgrade the bios firmware....If it still doesn't turn on then its something to do with motherboard...
Posted on Aug 07, 2009
Aideranil
  • 10 Answers
SOURCE: acer aspire 5920 won't read boot config data on start up
hi friend,
operating system of your laptop has crashed. you have to reinstall operating system. entire data which was stored on desktop, My documents will be lost.
Turn on your laptop and open DVD rom. Insert bootable CD which you might got with laptop. then it will start itself. and follow the instructions given on the screen.
Your friend,
Anil
Posted on Sep 21, 2009
Why is my laptop is stuck in start up mode. solution 1 did not work, the screen i come to has 2 options launch repair and start normally, the launch repair does not work but the start normally option is...
Hi you should keep on tapping F8 while booting so that an option will appear to select safe mode. or if you have a recovery CD restart the computer then press F2 or Delete to access the Bios Page look for Boot Options and change the first boot priority to your CDROM restart the computer and just follow the instruction on the recovery disk.
Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
How do I download a recovery disk free for an acer aspire 5920?
You most likely can't. OEM system builders...HP, Acer, Lenov, DELL usually don't provide a recovery disk with their laptops so they can charge you later when you need it. This is done to keep their costs down and increase profit.
Most cases, when you got your new laptop, there were instructions to "Create Recovery discs". But 99% of most users never do.
Result: you will need to call Acer and order the recovery discs or see if anyone has them on ebay/craigslist cheaper. Acer is best bet, so you don't end up with wrong or non-working discs and prolong your problem. Should be about $25-50 including shipping.
Feb 16, 2010 | Acer Aspire 5920-6335 Laptop
My acer laptop 5920 aspire switches on and off
If you have the systems recovery program or the discs, give that a try. Sounds like your start up files may be corrupted
Nov 08, 2009 | Acer Aspire 5920-6727 Notebook
Recovering windows vista
it probably load drivers it needs automatically, you don't have to make selection on which one.
Aug 20, 2009 | Acer Aspire 5920-6727 Notebook
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Can't get the system to boot in any configuration
Hi there.
The system files have become corrupt so it won't start properly, the only option left for you to do is recover the system.
If you didn't get any recovery disks with the laptop then you must use the recovery partition.
As the computer starts you can try ALT+F10 or CTRL+F10 during the initial boot cycle - this will prompt the laptop to access the recovery partition on the hard drive.
Good luck
Jun 01, 2009 | Acer Aspire 5920-6335 Laptop
Windows failed to start !...
if you had the recovery disk it would not clear the c drive it would just set it back to when you got it but the programs would still be there this computer i a,m on know had trhe same thing done to it and i was able to recover it without losing any info if you can get into bios and set it back to defaut or fail safe options you may be able to get going from there
Feb 17, 2009 | Acer Aspire 5920-6727 Notebook
The system cannot find the specified file
It seems as though your windows is corrupted. To solve this I would recommend a recovery back to factory settings but this will delete all the data of the computer.
You can save your data by
using an IDE/ATA to USB adapter on another computer or take it to computer store.
To begin the recovery
Remove all external devices like printers, mp3 players etc
Ensure the laptop is running on ac power
You can start the Recovery from outside Windows by holding down ALT and F10 on the Acer BIOS splashscreen on power up.
Jan 19, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
